It is currently Thu Nov 12, 2026 9:03 pm
 Post subject: Bucket fill tool (and others) not working. (solved)
PostPosted: Tue Apr 21, 2026 11:45 am  (#1)
GIMP Version: 2.8.14
Operating System: Windows
OS Version: Windows 11
GIMP Experience: New User
Here's what I've tried:
1. Uninstalling GIMP and installing the latest version (3.2.4)
2. Selected a layer group (Turn Off Before Exporting TGA) and went to Layer -> Layer Boundary Size. I made sure the values were correct (Width: 2048, Height 2048, Offset X: 0 and Offset Y: 0)
3. Selected another layer group (Paintable Area) and did the same thing. The purpose being to make sure both of the layers were exactly on top of one another as well as directly over the base canvas.
4. I've restored from several backups made over the last days, which were working at the time the backup was made. When restored the same problem occurs. It sure feels like this is a GIMP setting problem and not a project file problem.
5. From reading as much as I could before bothering you guys/gals I also heard of this concept of GIMP "failing silently" ... wtf does that mean?
Sometimes bucket fill works ... sometimes it doesn't ... this is infuriating and a huge waster of my time. Please help. Thanks in advance
UPDATE:
It happens as soon as I drop any .png onto the Layer Group "Paintable Area". I'm painting an iRacing Car and the templates come in the form of an Adobe Photoshop file. After the conversion, a message pops up saying "Compatibility Notice: This PSD file contains features that are not yet fully supported in GIMP: Layer effects are not yet supported and will show up as empty layers."
I tried to attach a .zip of my .xcf file but it is 1MB too large (limit 6MB) ... darn.
-Charles
 Post subject: Re: The bucket fill tool (along with many others) is not working ...
PostPosted: Tue Apr 21, 2026 6:25 pm  (#2)
Hello Charles and welcome to Gimp Chat.
:jumpclap :clap :jumpclap
It’s almost always some hidden condition.
In GIMP, bucket fill “randomly failing” is usually one of these:
1. You have an active (invisible) selection → Select → None
2. You’re on the wrong layer (group, locked, or hidden)
3. Bucket Fill is set to “Fill similar colors” with low threshold
4. It’s set to “Fill transparency” instead of FG color
Check for these,
fixing them should resolve the behavior.
If not, hopefully others will chime in.
PostPosted: Tue Apr 21, 2026 6:51 pm  (#3)
#1 ... thank you so much!!!
-Charles
PostPosted: Tue Apr 21, 2026 10:45 pm  (#4)
For most tools as Wallace mentioned; if you have an active selection and try to do something outside of that selection your tool will not work.
Usually, if you are working with xcf's a newer version will not be compatible with a older one.
Gimp vs 3 has not many plugins as yet and I'm not sure that any photoshop stuff will not work with it yet either. Used to much earlier on. Please let me know if that is wrong.
I have never heard of 'Gimp failing silently" so looked it up for you (& also for myself).
Common Causes of GIMP Failing Silently
GIMP may fail to start or crash without displaying error messages due to several reasons. Here are the most common causes:
Incompatible Plugins
Plugin Issues: Some plugins may not be compatible with the current version of GIMP, leading to crashes or silent failures.
Removing Plugins: If you suspect a plugin is causing the issue, try removing it from the GIMP plugin directory.
System Conflicts
Library Conflicts: Conflicts with system libraries or dependencies can cause GIMP to fail silently.
Operating System Updates: Recent updates to your operating system may introduce compatibility issues.
Troubleshooting Steps
To diagnose and resolve the issue, follow these steps:
Start GIMP from the Command Line: This can reveal error messages that are not shown in the graphical interface.
Open a terminal and type gimp.
Look for any error messages that appear in the terminal.
Check for Plugin Errors: If you see errors related to specific plugins, consider removing or updating those plugins.
Revert to Previous Version: If the issue started after an update, reverting to an earlier version of GIMP may resolve the problem.
Update System Libraries: Ensure that all system libraries and dependencies are up to date.
Additional Tips
Backup Configuration: Before making changes, back up your GIMP configuration files located in ~/.config/GIMP/.
Community Support: If issues persist, consider seeking help from GIMP community forums or support channels.
By following these steps, you can identify and potentially resolve the silent failure of GIMP.
PostPosted: Sat Apr 25, 2026 7:53 pm  (#5)
-Charles
Number one seems to be the most popular.
That's why I put it first.
:hehe
We're going to consider this one solved.
If you believe this was done in error,
contact one of us moderators about the issue and we'll correct it.
