It is currently Thu Nov 12, 2026 7:00 pm
 Post subject: Recomended add ons/plug-ins
PostPosted: Sat Sep 12, 2026 9:37 pm  (#1)
GIMP Version: 3.2.4
Operating System: Windows
OS Version: 10
GIMP Experience: New User
I was wondering what plug ins are worth downloading. I just checked out G'mic which is pretty neat to mess with. Thanks for any recommendations! :tyspin
 Post subject: Re: Recomended add ons/plug-ins
PostPosted: Wed Sep 16, 2026 6:55 pm  (#2)
I can confidently recommend any of Ofnuts' GIMP path tools.
The path-inbetweener script by Ofnuts is a popular one of many.
Check it out here on Gimp Chat.
path-inbetweener
PostPosted: Thu Sep 17, 2026 1:01 am  (#3)
It is not for GIMP3, is it?
GIMP 2 plug-ins do not work in GIMP 3.
For me must have plug-ins are for example:
GMIC, Batcher, resynthesizer
But as a new user I would first start to learn GIMP without plug-ins.
PostPosted: Thu Sep 17, 2026 2:30 am  (#4)
I agree with all of that, especially the last bit, experiment with Gimp and find out how it works.
Ofnuts does have some Gimp 3 plugins here: https://sourceforge.net/projects/gimp3- ... s/general/
A remake of Ofnuts text along path is here: https://github.com/Vekz/vekz-text-along-path
There are Mark Sweeney plugins https://script-fu.github.io/funky/hub/plug-ins/folder/
There is a certain amount of duplication, Batcher for example, renames layers / add backgounds, all sorts of things...but you might find a single simple plugin that suits your workflow better.
