It is currently Mon Aug 17, 2026 11:19 am
 Post subject: Script error or not?
PostPosted: Thu Apr 10, 2014 2:55 am  (#1)
I have just installed the Antique Metal script and gmic_gimp and when I tried to create a logo I got the following messages: [edit)
I am running with Gimp 2.6.12 on Linux Mint 32bit using gmic_gimp linux32 and Antique Metal.scm rel 0.01
Am I doing something wrong or is there a glitch somewhere?
Many thanks
J
 Post subject: Re: Script error or not?
PostPosted: Thu Apr 10, 2014 6:05 am  (#2)
You must have Gmic installed to run this script, I'll post your error for you
could you reply to inform me if you have the Gmic plugin installed
PostPosted: Thu Apr 10, 2014 6:27 am  (#3)
gmic_gimp plugin is located in /home/john/.gimp-2.6/plug-ins. (configured to execute)
G'Mic also exists within the "filters" tab. (vers 1.5.8.5. linux32)
I will fire up gimp on my old Win7 machine and install gmic and antique. Just to see. Probably get back to you sometime tomorrow (Fri 11 Apr).
PostPosted: Thu Apr 10, 2014 6:35 am  (#4)
can you open gmic OK
PostPosted: Thu Apr 10, 2014 6:55 am  (#5)
Yes I can. In both Linux and Win7. (still in the process of install antique metal plugin)
PostPosted: Thu Apr 10, 2014 7:04 am  (#6)
Ran Antique Logo on Win7 and ran like a charm... Woo Hoo!
PostPosted: Thu Apr 10, 2014 7:11 am  (#7)
I see your from Melbourne, I'm from Bendigo
Glad you have it working, but it should run on your Linux
PostPosted: Thu Apr 10, 2014 7:19 am  (#8)
Hope you have enjoyed the rain...
Yes. It should run on Linux.
Just a point. My Win7 machine use Gimp 2.8. Might be a good idea if I update Gimp on my Linux box. I will try it tomorrow and get back to you. My brain hurts and I think I need either sleep or coffee....
PostPosted: Thu Apr 10, 2014 7:26 am  (#9)
I wrote the script on Gimp 2.6 so that is not the problem, what gmic version do you have on your Linux
PostPosted: Thu Apr 10, 2014 7:50 am  (#10)
Same version.
Could not wait until tomorrow. Updated Linux Gimp to 2.8.10. The Antique Metal worked like a charm. Looks like the upgrade to Gimp 2.8 did the trick! Woo Hoo!
Now where did I put my coffee....?
Many thanks for the assist. As my "artistic" talents are somewhat lacking, I will probably have more questions, down the track. Have a good night.
Cheers
J
cron
