It is currently Sat Nov 28, 2026 11:39 pm
Post new topic Reply to topic  [ 96 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Tree bark (Script)
PostPosted: Wed Jun 11, 2014 7:21 pm  (#1)
This script runs steps 8-13 of Tree Bark Text tutorial (Link deleted go here:Tree Bark Text Tutorial
0) You need to have layerfx.py installed (copied to your gimp's plug-ins folder). You can get it here layerfx plugin
1) To run this script with defaults of conbagui, you must copy conbagui's "mossy bark texture gray.jpg" and "Mossy bark texture.jpg" into your gimp's patterns folder.
2) Copy this script into your gimp's scripts folder (will be available under Script-Fu -> Alpha-to-Logo -> Tree bark)
Tree_bark.scm [4.47 KiB]
Downloaded 694 times
4) On a new layer, draw your artwork (example shown below)
5) Select/highlight the new layer with artwork, and run script-fu -> Alpha-to-logo -> Tree bark, options you can change shown below (defaults should be okay).
6) Click OK and let the script run and you'll get tree bark effect.
(examples shown below)
Last edited by trandoductin on Sat Aug 20, 2016 11:50 am, edited 4 times in total.
 Post subject: Re: Tree bark (tutorial by conbagui) (Script)
PostPosted: Wed Jun 11, 2014 8:14 pm  (#2)
Conbagui,
I cut and pasted a lot of code from glass stain window tutorial, just changed the numbers. :)
 Post subject: Re: Tree bark (Script)
PostPosted: Wed Jun 11, 2014 10:21 pm  (#3)
trandoductin, nice script!
When I ran the script for the first time, an error message appeared.
It seems that the textures were not located.
I closed the message, and ran the script again. This time the window with the textures to be selected emerged.
Maybe because I have not used the textures in .Jpg format, but .Pat
With just one click and voila :clap :jumpclap :bigthup
However, I noticed that the script produces a slightly different result of the tutorial.
Comparing the two results, changing the visibility between the two layers, it is easier to see the difference. (see in treebark.xcf)
I tried to do the uploading .xcf for the forum, but is larger than allowed. Then I tried with .rar, but the forum does not accept this format.
So I sent the treeback.xcf for Treebark.xcf
bbbbbbbbbbbImage
PostPosted: Wed Jun 11, 2014 11:10 pm  (#4)
i can't download your .xcf file it said i have to register :(
But i'll compare the script run with my "smooth" image when i followed the tutorial and see if there's any difference.
edit: you're right there is a difference. I'll have to double check my numbers see where i missed something.
edit: Yeah it was the inner shadow step i put a 45 instead of -45 for the angle. I changed it to -45 and updated the script.
PostPosted: Thu Jun 12, 2014 3:11 am  (#5)
Thank you trandoductin for your script. You're always so hardworking. :coolthup :clap
PostPosted: Thu Jun 12, 2014 4:29 am  (#6)
Brilliant artwork dalia. Thanx for the script tin.
PostPosted: Thu Jun 12, 2014 9:35 am  (#7)
Still having fun with the script here :hehe
bbbbbbbbbbbImage
PostPosted: Thu Jun 12, 2014 9:45 am  (#8)
Akros, that is great! really good! but... I'm afraid of him too. I can't see it! :coolthup
PostPosted: Thu Jun 12, 2014 10:03 am  (#9)
cool
PostPosted: Thu Jun 12, 2014 2:53 pm  (#10)
The script works fine now
PostPosted: Thu Jun 12, 2014 2:59 pm  (#11)
mackenzieh, what's the error?
PostPosted: Thu Jun 12, 2014 3:52 pm  (#12)
It was reading that the images that were .jpg files weren't reading. I had the same error that Akros had.
PostPosted: Thu Jun 12, 2014 3:59 pm  (#13)
if you didn't copy conbagui's .jpg files into patterns or if you've saved them as .pat files, then just ignore the error and choose your texture accordingly.
PostPosted: Thu Jun 12, 2014 6:51 pm  (#14)
Ok, that one scares me too but it's amazing Akros.
trandoductin, it is really amazing what you do. Thank you. Shoot, I ran the script and it came out looking perfect. When I went step by step in the original tutorial (I must have done something wrong which is usually par for the course with me) it didn't come out like this. I didn't do the extending branches cuz' it was a quick one but it really came out nice.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Sun Jun 15, 2014 4:38 am  (#15)
I've just seen this script (sorry, Tin!)
Downloaded and run my first trial.
Something different from Akros', for Issabella and Dalia.....
Thanks Tin
Thanks Conbagui
PostPosted: Sun Jun 15, 2014 12:49 pm  (#16)
Dinasset, that is wonderful, I like it very much indeed. I would have never thought to apply the script on such a nice images. The result is fantastic. Thank you so much dinasset. :clap
PostPosted: Sun Jun 15, 2014 12:58 pm  (#17)
muchas gracias, Issabella!
glad you like it!
PostPosted: Tue Jun 17, 2014 10:50 am  (#18)
another trial
PostPosted: Tue Jun 17, 2014 11:44 am  (#19)
nice furry creatures
PostPosted: Tue Jun 17, 2014 12:51 pm  (#20)
Dinasset, that is fantastic, I'm not afraid of them, :hehe Good job! :jumpclap
cron
