It is currently Sun Nov 29, 2026 8:06 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: Is there script/plug-in for doing pressed text?
PostPosted: Mon Jul 07, 2014 9:19 am  (#1)
Hi!
I haven't been here in so long! There's certainly no stopping creativity in this place! That's for sure!
Is there a script or plug-in out that can do pressed text? See the link for a Google Image search.
Google Image search of Pressed Text
I've had a need to use this effect more than a few times and gets to be a slight burden. Anything to make life .. more efficient is good! You thought i was going to say easier! =)
Hope you can help!
And as always thanks for the help!
 Post subject: Re: Is there script/plug-in for doing pressed text?
PostPosted: Mon Jul 07, 2014 10:07 am  (#2)
Very nice effects... couldn't this be done by using the map > bump map, then inverting to the depth you prefer?
PostPosted: Mon Jul 07, 2014 10:23 am  (#3)
I found these 2 tutorials on the subject. Take a look at them and see if they can be of some help to you. I think the first tutorial link might be able to be made into a script, but don't quote me on that.
https://www.youtube.com/watch?v=JiwrdMt1K6c
https://www.youtube.com/watch?v=KY6fzWOYtdU
PostPosted: Mon Jul 07, 2014 10:35 am  (#4)
not a script but there is a discussion about it here
http://www.gimpchat.com/viewtopic.php?f ... 5&start=10
Looks similar to the carved logo Image
with raised text
Image?
PostPosted: Mon Jul 07, 2014 10:40 am  (#5)
Or maybe this discussion where there are links to scripts: viewtopic.php?f=23&t=428
Kevin
PostPosted: Mon Jul 07, 2014 10:42 am  (#6)
Very effective Wallace, I liked them both but the bottom was much easier to follow. Top one was too fast and I missed half of it. :teeth
Sallyanne, yours is very good.
PostPosted: Mon Jul 07, 2014 11:04 am  (#7)
By the way the 'carved logo' can be found at file>create>logos>carved. It is almost like a script since there is not much effort on the users part.
PostPosted: Mon Jul 07, 2014 11:28 am  (#8)
Technically, it is a script...
PostPosted: Mon Jul 07, 2014 11:38 am  (#9)
Well there you go....Ofnuts you would know I am not a script person......Is this similar to pressed text?
PostPosted: Mon Jul 07, 2014 11:54 am  (#10)
You right about the video being hard to follow at times. Handy YouTube shortcuts; spacebar to pause/play and forward or back to 10% to 90% of video, number keys 1 to 9.
PostPosted: Mon Jul 07, 2014 12:17 pm  (#11)
Thanks Odin, I didn't know that. I must go look at it again. Cool
PostPosted: Mon Jul 07, 2014 2:51 pm  (#12)
What I mean is that when your use "file>create>logos>carved", it is not "almost like a script", it is a script (that comes with the rest of Gimp).
PostPosted: Mon Jul 07, 2014 3:10 pm  (#13)
Yeah you're right about the first tutorial. "Tutor4U" is a really good Gimp tutorial maker that's very easy to follow.
PostPosted: Mon Jul 07, 2014 5:56 pm  (#14)
That works very well ofnuts. I didn't even know it was there. :oops: :oops:
PostPosted: Mon Jul 07, 2014 8:00 pm  (#15)
First video I felt gave better results. The fellow got a little fuzzy once he started shifting the selection around. I've seen this tut before. What you never see is pressed in text on a light background using a darker text.
I know about this tut. But its falls very short on options.
I'm just surprised there's no automation for this type of effect as common as it is.
PostPosted: Mon Jul 07, 2014 8:28 pm  (#16)
there is my script 'pressed out text' ,just gota find it
Menu Location Script-Fu/Logos
Pressed out Text.scm [4.83 KiB]
Downloaded 203 times
PostPosted: Mon Jul 07, 2014 9:19 pm  (#17)
there is also gimps default carved script
PostPosted: Tue Jul 08, 2014 1:42 am  (#18)
You can get this effect pretty easy by using GC Shadow to create 2 shadows. Keeping shadows on top, create a black (or dark) inner shadow, then a white (or light) thinner drop shadow.
PostPosted: Tue Jul 08, 2014 1:53 am  (#19)
That looks very simple but effective GnuTux :bigthup
PostPosted: Tue Jul 08, 2014 2:06 am  (#20)
GnuTux, the text master!
