It is currently Wed Aug 19, 2026 9:11 pm
 Post subject: Spyrogimp - forgot filter?
PostPosted: Sat Oct 04, 2014 6:35 pm  (#1)
 Post subject: Re: Spyrogimp - forgot filter?
PostPosted: Sat Oct 04, 2014 6:49 pm  (#2)
Thanks Marcello its a nice script
PostPosted: Sat Oct 04, 2014 6:54 pm  (#3)
Looks like a slinky.
PostPosted: Sat Oct 04, 2014 7:30 pm  (#4)
Molly it makes nice borders
PostPosted: Sat Oct 04, 2014 8:19 pm  (#5)
PostPosted: Sat Oct 04, 2014 9:44 pm  (#6)
PostPosted: Sat Oct 04, 2014 11:51 pm  (#7)
launched the filter with defaults, got the following error:
GIMP Error
Calling error for procedure 'gimp-brush-get-pixels':
Procedure 'gimp-brush-get-pixels' has been called with value '(null)' for argument 'name' (#1, type gchararray). This value is out of range.
is my version out of date?
(in spite of the error message the spyrograph is produced)
PostPosted: Sun Oct 05, 2014 12:47 am  (#8)
maybe you do not have the default brush, use the brush widget to select another
PostPosted: Sun Oct 05, 2014 1:51 am  (#9)
thanks Graechan
edit: the script window does not accept the click on "browse" for the brush (?)
PostPosted: Sun Oct 05, 2014 1:59 am  (#10)
Where can I find this?
Found it but can't make a frame. Can someone please tell me how it is done?
PostPosted: Sun Oct 05, 2014 2:23 am  (#11)
Dinasset can't see why? it would not are you using 2.8.10 or 14
Sallyanne look under Filters/Render
PostPosted: Sun Oct 05, 2014 2:35 am  (#12)
Conbagui how on earth did you do that
PostPosted: Sun Oct 05, 2014 2:38 am  (#13)
Graechan, I discovered why (and I put this info here in case somebody else should encounters this strange behaviour):
- if on the tool option the active brush is empty, than the "browse" option does not work
Strange, isn't it?
Whatever is in the active brush EXCEPT EMPTY, everything OK:
-the script does not send an error message (it looks likely to the active brush and in the empty case gives the message I posted)
-when clicking the "browse" buttom you get the selection window
"tutto è bene quel che finisce bene" (Italian motto)
PostPosted: Sun Oct 05, 2014 2:52 am  (#14)
I found it before but every time I try to do a frame it goes over my picture, not around it.
PostPosted: Sun Oct 05, 2014 2:57 am  (#15)
Dinasset thanks for letting me know the reason
Conbagui did you have a selection in place and could you post your settings
PostPosted: Sun Oct 05, 2014 3:01 am  (#16)
:coolthup conbagui
PostPosted: Sun Oct 05, 2014 9:25 am  (#17)
Always loved this one. Been a while since i've used t. :)
PostPosted: Sun Oct 05, 2014 5:13 pm  (#18)
PostPosted: Sun Oct 05, 2014 5:37 pm  (#19)
using butterflies brush
PostPosted: Sun Oct 05, 2014 5:54 pm  (#20)
Did Mine with strawberry brush
