It is currently Fri Aug 28, 2026 11:20 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: The IFS plugin now working OK
PostPosted: Fri Oct 24, 2014 1:22 am  (#1)
The IFS plugin seemed to continually fail in my Gimp but now is larger and more reliable
To download file from the registry click here IFS
Input image
Menu setting
Result
 Post subject: Re: The IFS plugin now working OK
PostPosted: Fri Oct 24, 2014 2:38 am  (#2)
for Issabella, when she will come back...
PostPosted: Fri Oct 24, 2014 2:42 am  (#3)
good result Dinasset :bigthup
PostPosted: Fri Oct 24, 2014 2:51 am  (#4)
thanks, Graechan
it does almost everything the filter...
PostPosted: Fri Oct 24, 2014 11:25 am  (#5)
Thank Graechan
my tentative
PostPosted: Fri Oct 24, 2014 12:20 pm  (#6)
Forgot all about this plugin in; looked in my archive and found samj's 64-bit compile (she no longer hosts) and it works great. Thanks for reminding me of this cool plugin Graechan. :)
PostPosted: Fri Oct 24, 2014 6:23 pm  (#7)
the plugin posted on the Registry is 32bit
PostPosted: Fri Oct 24, 2014 6:28 pm  (#8)
Yeah; had samj's compile. She no longer hosts it though unfortunately. Not sure if she ever posted it here at her resource thread or not. :)
PostPosted: Fri Oct 24, 2014 6:34 pm  (#9)
now I have the 32bit and 64bit compiles
PostPosted: Fri Oct 24, 2014 7:02 pm  (#10)
Here is the 64 bit i compiled today. Tested in GIMP-2.8.10 on Windows 8.1 64bit.
ifs-64bitWin_RD.zip [22.27 KiB]
Downloaded 241 times
PostPosted: Fri Oct 24, 2014 7:05 pm  (#11)
One more example with different settings.
PostPosted: Sun Jan 18, 2015 6:52 pm  (#12)
Greetings. Is there an OSX build for the IFS plugin available? I see no comprehensible guides anywhere regarding getting IFS working on OSX.
In fact there's this extremely discouraging note in the G.I.M.P. manual:
"If you on the other hand are one of the Users that preferred to grab a prebuild GIMP package like GIMP.app, you most probably want to stick to that prebuild stuff. So you can try to get a prebuild version of the plugin of you dreams from the author of the plugin, but I'd not want to bet on this. Building your own binaries unfortunately involves installing GIMP through one of the package managers mentioned above."
(from the scripts section of the gimp manual)
Regards
PostPosted: Sun Jan 18, 2015 7:19 pm  (#13)
for use on OSX you could try compiling and test it out but I do not know of any builds that have been done
PostPosted: Sun Jan 18, 2015 7:39 pm  (#14)
Thanks. I haven't found any comprehensible information on compiling it without building from FINK.
Theres really no way to install the newest version of GIMP (x11 independent) and get plugins to work without going through a 3 hour compile time?
That seems excessively user un-friendly.
Further suggestions appreciated :)
PostPosted: Sun Jan 18, 2015 7:49 pm  (#15)
Gimp 2.8.14 is available for OSX from here Partha's Place
PostPosted: Sun Jan 18, 2015 8:03 pm  (#16)
Ok I tried that link.
All it does is re-skin what I already have, and doesn't get me any closer to any IFS functionality.
(But the new skin looks fun)
Am I missing something in the interface? I tired searching for IFS in the help area.
PostPosted: Sun Jan 18, 2015 9:13 pm  (#17)
can you be more explicit about your problem e.g. plugin not running correcty, also the help area will be of no use as it's not a default plugin
PostPosted: Mon Jan 19, 2015 12:03 am  (#18)
ifs-64bitWin_RD.zip
How do we install and it and run it? I'm using windows 7 64bit
PostPosted: Mon Jan 19, 2015 12:32 am  (#19)
ifs-64bitWin_RD.zip
place it in your plugins folder and restart gimp, open an image then go to Filters/Misc/IFS and select,
your Menu will look like this↓
PostPosted: Mon Jan 19, 2015 12:55 am  (#20)
Graechan wrote:
ifs-64bitWin_RD.zip
It works.
