It is currently Wed Sep 16, 2026 10:49 am
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
 Post subject: LIST OF FILTERS MAKING FRAMES AND BORDERS
PostPosted: Mon Nov 24, 2014 1:43 pm  (#1)
I am trying to have a list to understand better the possibilities, avoid double filters and start to analyse better each filter.
My idea is to update this topic with the results
Any suggestion and contribution is highly appreciated
Thank you Marcello
SUMMARY OF FILTERS REFERRING FRAMES BORDERS AND SIMILARS IN GIMP AND GMIC
First group FILTERS>DÉCOR
Add Border
Add Matt
Add Frame
Apply Border
Create Border
Fuzzy Border
Gradient Stroke
Round Corners
Slide
LineBorder2
Frame Factory
Second group FX-FOUNDRY>IMAGE EFFECTS
Double Border
Alexios Photo Frame
Third group SCRIPT-FU>EDGES
Picture-Frame
Fade Outline
Gradient Frame
Jagged Border
Pixel-Frame
Translucent Border
Art Border
Frame like Poster
Frame like Slide
Frame with hover
Photo Border Fancy
Photo Frame
Tasty Frame – optional Title
4th group FILTERS>BEAUTIFY>BORDER
Rip Border
Simply Border
Texture Border
5th group MISCELLANEOUS
Script-Fu>Frames>Glass Frame Effect
Script-Fu>misc>Stickit
Script-Fu>BWborderV2
ICCII>Layers Effect>Add Border
6th group GMIC>Frames
Drost
Frame blur
Frame cube
Frame Fuzzy
Frame Painting
Frame pattern
Frame regular
Frame Round
Polaroid
Tunnel?
Vignette
7th group GMIC>Testing>Samj>Frames
Cadres rotation CS TV
Cadres serie TV
Cadre image001
Cadre image002
Des lignes 001
Des lignes 002
Expand xy 001
Filets 001
Gradient 001
 Post subject: Re: LIST OF FILTERS MAKING FRAMES AND BORDERS
PostPosted: Mon Nov 24, 2014 2:10 pm  (#2)
tests of 1st group
(I dont show very simple filters and filters that you can find in other group with more capabilities)
Frame Factory
Pin-Strip Border
PostPosted: Mon Nov 24, 2014 3:05 pm  (#3)
tests 2nd and 3rd group(part I)
Gradient Frame
notes-
1. in my opinion Picture-frame is one of the best filters to make frames
2. Fade Outline for my tests works better if you click only one of the four alternatives and some of that need a selection before
the test Fade Outline has the faded line trasparent but here is white as the file is jpg
3. Gradient Frame with the 22 Crown Mouldings Gradients is an other fantastic tool
PostPosted: Mon Nov 24, 2014 3:52 pm  (#4)
tests 3rd group(part II)
PostPosted: Mon Nov 24, 2014 4:54 pm  (#5)
Not sure if you have this one yet. Filters>Decor>Borders>Line Border 2.
http://registry.gimp.org/node/24784
GLADE DLL files for Windows- Place these dll files in the GIMP-2.8/bin directory. This worked for me in 64 bit GIMP-2.8.14. This Border tool is tabbed.
http://registry.gimp.org/files/add%20gl ... _32bit.zip
PostPosted: Mon Nov 24, 2014 8:48 pm  (#6)
I do not know if they were already mentioned but here are some of mine
Picture Frame (has a plugin dependency 'wrap bitmap')
Pixel Frame
Borderise (actually an unfinished badge script)
Gradient Frame
PostPosted: Mon Nov 24, 2014 9:11 pm  (#7)
thank you for the answer, you are right I forgot to list cause I failed weeks ago to install
here was my tentative
1. In user>.gimp-2.8 I opened two sub-directories : python and bin
2. In python I created a sub-directory LineBorder-2.4.2 and I moved these files
_ini_.py
Gui.py
LineBorder.glade
LineBorder.py
LineBorderProfile.py
TreeViewTooltips.py
And also
.gitignore
Kym-Border.py
3. Always under pyton directory I opened another sub-directory lib/site-packages/.gtk-2.0/gtk/glade.pyd
4. In sub-directory bin I moved these files
libglade-2.0-0.dll
libxml2.dll
5. Preferences>Folders>Plug-in
User/.gimp-2.8/python/LineBorder-2.4.2
Result : I could see the item in Filters>Décor>Borders>LineBorder2
But when I click over nothing happen
where I failed?
PostPosted: Mon Nov 24, 2014 10:03 pm  (#8)
Thank you Graechan
* Picture Frame and Pixel Frame were already
* where I can find Borderise
* big mistake now Gradient Frame is in the list and show..sorry
PostPosted: Mon Nov 24, 2014 11:19 pm  (#9)
Wow!
I had no idea there were so many frames and borders. Looks like there all over the place too.
PostPosted: Tue Nov 25, 2014 1:56 am  (#10)
Marcello Borderize has never been posted it's just a roughy I created some time ago
PostPosted: Tue Nov 25, 2014 7:25 am  (#11)
Not 100% sure but I do not think this one has been included.
rayadagio Framefactory plugin
This was posted here http://forum.meetthegimp.org/index.php?topic=1438.0
but looks like the link is gone.
attached for anyone who wants to try it. Python plugin, remember to unzip it.
File comment: Frame Factory (Updated by Graechan)
FrameFactory.zip [4.46 KiB]
Downloaded 541 times
PostPosted: Tue Nov 25, 2014 7:36 am  (#12)
_ini_.py
Gui.py
LineBorder.glade
LineBorder.py
TreeViewTooltips.py
And also
.gitignore
Kym-Border.py
libglade-2.0-0.dll
libxml2.dll
where I failed?
The pyd file should be in program files/GIMP 2/python/lib/site-packages/.gtk-2.0/gtk/ folder
dll files should be in program files/GIMP 2/bin/ folder
Everything else should be in user/.gimp-2.8/plug-ins folder.
PostPosted: Tue Nov 25, 2014 8:34 am  (#13)
Is there a reason no one ever mentions the border in selection?
There are a few of those I do not have. Another one that wasn't mentioned in decor is slide. Thought I saw them all.
PostPosted: Tue Nov 25, 2014 9:28 am  (#14)
Pin-Stripe Border Script
viewtopic.php?p=27323#p27323
PostPosted: Tue Nov 25, 2014 10:15 am  (#15)
I like this filter! Thank you to show to me; I updated the list and the show
(it is under Filters>Decor)
PostPosted: Tue Nov 25, 2014 10:18 am  (#16)
the file glade.pyd was already there
file libxml2.dll was already , I added libglade-2.0-0.ddl
all other files copied here
NO LUCKY :gaah
maybe is not working on Vista32bits
I also delete pluginrc and restart no way
when I start GIMP it shows a strange list releted to the file Treeviewtooltips !?!
PostPosted: Tue Nov 25, 2014 10:26 am  (#17)
sallyanne wrote:
[align=center]Is there a reason no one ever mentions the border in selection?
Well, I was thinking about that but i decided not to include the "indirect"
possibilities to create a border
Maybe we can make a special section for that staff
Glad that you check the list :yes
PostPosted: Tue Nov 25, 2014 10:48 am  (#18)
Sorry, I didnt find it before :mrgreen: , I add to the list and I show bigger than default
PostPosted: Tue Nov 25, 2014 10:59 am  (#19)
I think can be an interesting script, why dont finish it?
PostPosted: Tue Nov 25, 2014 9:05 pm  (#20)
4th and 5th groups
BWborderV2
Here we have realy beautiful filters
Beautify>Border has a lot of masks;
with Glass Frame Effect you can have splendid compositions
but I want to give some info on ICCII-Effects-AddBorder:
try these settings
a.Border Fill Type: GRADIENT
b.BlendMode: CUSTOM GRADIENT
d.CustomGradient: Three bars or CrownMoulding or Banded BGN-FG-WBG
e.GradientStyle: Shaped Sph
need alpha channel
