It is currently Tue Aug 18, 2026 4:25 am
 Post subject: Spirograph... how is it used?
PostPosted: Tue Jan 20, 2015 8:56 am  (#1)
I have the spirograph plugin and I'm not sure how it is used. I get that it creates paths. My thing is, after it creates the path, how can it be viewed? Does the spirograph have to be created on a transparent layer?
 Post subject: Re: Spirograph... how is it used?
PostPosted: Tue Jan 20, 2015 9:10 am  (#2)
Do you mean Spyrogimp (under render)? It actually plots these type renderings. :)
PostPosted: Tue Jan 20, 2015 9:14 am  (#3)
No, I'm referring to Spirograph by Bytes-and-Pixels.com.
It can be found under Filters>Bytes-and-Pixels.com>Spirograph
PostPosted: Tue Jan 20, 2015 9:22 am  (#4)
Don't actually have that one. If it creates paths, then what you do is open the paths dialogue box (I actually have a parked tapped for paths; you may not in your dock) and then you will see the path. If so, all you need to do to use the path is to stroke path. :)
PostPosted: Tue Jan 20, 2015 9:26 am  (#5)
Oh, okay. Thanks Lyle. :)
PostPosted: Tue Jan 20, 2015 10:22 am  (#6)
Yes just move one path a few pixels then right click the path layers and stroke. I usually stroke with a line of 1 pixel.
PostPosted: Tue Jan 20, 2015 8:37 pm  (#7)
maybe can be useful
http://www.gimpchat.com/viewtopic.php?f ... 35b7f87d62
