It is currently Wed Aug 26, 2026 1:24 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Star Effect Filter Scripts Rel3.2 (bugfix)
PostPosted: Fri Jan 23, 2015 8:05 pm  (#1)
creates a 'Star Effect' as per the images below
Original
Soft Result
Hard Result
Menu Locations
Filters/Light and Shadow/Star Effect Filter/Star Effect Hard
Filters/Light and Shadow/Star Effect Filter/Star Effect Soft
; Rel 0.02 - Just better now with 2 Scripts
; Rel 2.1 - Added more adjustments to the filters
; Rel 3.0 - Added setting for number of spikes
; Rel 3.1 - added more checks and balances
; Rel 3.2↓ - Improved layer merging
Star Effect Filter.scm [8.18 KiB]
Downloaded 442 times
 Post subject: Re: Star Effect Filter Script
PostPosted: Fri Jan 23, 2015 8:43 pm  (#2)
Looks as though I've seen this filter before Graechan, Is this a re-work of the original one?
PostPosted: Fri Jan 23, 2015 8:53 pm  (#3)
Thank you Conbagui, I'm hoping to change to the Gmic 'Blur [linear]' filter for this instead of Gimps 'Motion blur' as it is faster
Here is the image before blurring
This is the result
Wallace no it's not it was written as a reply to this recent post Would like a diffraction spikes filter using this tutorial Scott photo graphics
PostPosted: Fri Jan 23, 2015 10:03 pm  (#4)
Yes I have sinned and strayed away from the tutorial to create this
PostPosted: Fri Jan 23, 2015 10:14 pm  (#5)
This is a good one G! Thanks!
 Post subject: Re: Star Effect Filter Scripts
PostPosted: Fri Jan 23, 2015 11:34 pm  (#6)
Wow, that was quick! Nice filter, many thanks. :jumpclap
On this one, I changed the filter layer from "screen" to "lighten only."
 Post subject: Re: Star Effect Filter Scripts Rel2 (2 menus Hard and Soft)
PostPosted: Fri Jan 23, 2015 11:41 pm  (#7)
Rel2 has just been posted and has 2 scripts see initial post
Acmespace Thanks for testing, try the Rel2
PostPosted: Sat Jan 24, 2015 12:06 am  (#8)
New scripts (Rel. 0.02) on a 656x804 image, filters in default settings. Lookin' good.
PostPosted: Sat Jan 24, 2015 12:38 am  (#9)
Acmespace it didn't take you long to update, note I think your Image has too many light sources and you should try one with less
like this
PostPosted: Sat Jan 24, 2015 2:18 am  (#10)
True, I wouldn't normally use a star filter on those holiday light photos. But I'm playing with a new toy!
PostPosted: Sat Jan 24, 2015 6:41 am  (#11)
Nice one Graechan! :)
Duplicated the star layer a few and gave it a black bg as it shows the outside glares better.
PostPosted: Sat Jan 24, 2015 3:10 pm  (#12)
I saw the image Rod made and I just had to try that out for myself.
PostPosted: Sat Jan 24, 2015 5:16 pm  (#13)
Thanks Rod and Wallace for trying out the Star Effect Filter
PostPosted: Sat Jan 24, 2015 5:25 pm  (#14)
Here's my try
1st pic,moved the spike slider to 60: looks like a canvas
the second,i changed the the star effect layer to burn:
PostPosted: Sat Jan 24, 2015 5:39 pm  (#15)
Thank you Graechan, this looks awesome! I can hardly wait to try it. I'm in the middle of a 2 day CG render right now but I'll post my result with this script asap.
PostPosted: Sat Jan 24, 2015 5:56 pm  (#16)
pirate541 your settings were too high try something lower, to pickup only the high intensity light
PostPosted: Sat Jan 24, 2015 6:51 pm  (#17)
No problem Graechan, It works great. :bigthup
PostPosted: Sat Jan 24, 2015 7:17 pm  (#18)
Wallace This is from using the soft filter in Rel2.1, to be posted soon
 Post subject: Re: Star Effect Filter Scripts Rel2.1 (Added adjustments to soft filte
PostPosted: Sat Jan 24, 2015 7:53 pm  (#19)
Rel2.1 now out see initial post this release has additional controls for the soft filter see new output above
PostPosted: Sat Jan 24, 2015 8:16 pm  (#20)
Nice addition Graechan. :jumpclap
I could see how someone might want to play with these sliders/settings. Thanks for the update. :bigthup
