It is currently Fri Aug 21, 2026 3:04 am
 Post subject: Gimp Guides Lab
PostPosted: Tue Mar 10, 2015 2:28 pm  (#1)
At the Gimp Shape Creator 6e web site and I noticed Gimp GuidesLab. I would rate it as an excellent Gimp Guide plug-in with advanced options, definitely worth a look. There is a tiny learning curve but overall straight forward. Just remember if you make a mistake it's, "Double click to delete the current guide.". Go for the 'arakne-guide-labB' version with the handy mirror option.
 Post subject: Re: Gimp Guides Lab
PostPosted: Wed Mar 11, 2015 9:18 am  (#2)
Find guides very useful
Thx
PostPosted: Wed Mar 11, 2015 5:56 pm  (#3)
There are multiple options for advanced creation of guides :)
PostPosted: Wed Mar 11, 2015 6:35 pm  (#4)
Thank you prokoudine, These are very good explanations for using guides.
PostPosted: Fri Mar 13, 2015 1:04 pm  (#5)
I remember reading that article prokoudine, thanks for adding the link. Give Gimp GuidesLab a go, I think it's worthy of your list.
