It is currently Tue Aug 18, 2026 12:37 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: Wavelet-Denoise-jthack-windows 32 and 64 bit
PostPosted: Fri Mar 27, 2015 6:17 am  (#1)
32 and 64 bit compiles are attached. I did not include the src files.
USE AT YOUR OWN RISK!
Filters>Enhance>Wavelet Denoise
This is the 64 bit version on my machine in GIMP-2.8.14.
Download here- No DOS popup
viewtopic.php?f=9&t=12220&p=165762#p165762
 Post subject: Re: Wavelet-Denoise-jthack-windows 32 and 64 bit
PostPosted: Fri Mar 27, 2015 6:29 am  (#2)
What's different from the hack then from the original wavelet-denoise (which I do use often) Rod? :)
PostPosted: Fri Mar 27, 2015 6:33 am  (#3)
This "hack" just allows the filter settings to be passed as parameters if the filter is invoked non-interactively, as requested by Dinasset in this thread:
viewtopic.php?f=8&t=12199
PostPosted: Fri Mar 27, 2015 6:36 am  (#4)
For scripting i suppose. :)
PostPosted: Fri Mar 27, 2015 6:39 am  (#5)
@Rod
Why do you get a Dos window pop up when you run it?
I'm sure that didn't happen with the stable version on Windoze.
Are you sure you compiled this right?
PostPosted: Fri Mar 27, 2015 6:42 am  (#6)
jontait2 wrote:
@Rod
Yes i did i just forgot to add something to the makefile for windows compiles. :) The window can be minimized if it's in the way.
I actually could not get the 32 bit to compile until i used a different bat file to run msys.
PostPosted: Fri Mar 27, 2015 7:17 am  (#7)
many many thanks, Rod! this completes the gift from jontait2 (source modified)
and allows me to perform tests in a much more comfortable manner...
PostPosted: Fri Mar 27, 2015 7:34 am  (#8)
No problem. Glad to help. :)
PostPosted: Fri Mar 27, 2015 9:13 am  (#9)
http://gimpchat.com/viewtopic.php?f=8&t=12199
jontait2, I would like to check my understanding about the parameters (according to your explanations on previous topic)
assuming to work on colour images I have to:
- select colour-mode (0=YCBCR, 1=RGB, 2=LAB), that's apparently easy except for
my first question: online the sequence is YCRCB, CIELAB, RGB
which one of the two sequences is correct? or both because the online CIELAB is set as 2 in the program and RGB as 1?
- ignore the following 4 parameters because related to grey images
- insert the threshold value on colour-thresholds 0,1,2 either for (respectively)
Y,Cb,Cr if YCBCR selected
R,G,B if RGB selected
L,a,b if CIELAB
is it correct?
- ignore the 4° value ?
- same as above for softness ?
sorry for my ignorance, but I want to start my tests appropriately
many thans
PostPosted: Fri Mar 27, 2015 9:51 am  (#10)
AFAIK your interpretation is correct:
- the colour modes are { 0=YCBCR, 1=RGB, 2=LAB } internally to the plug-in and (now) in the PDB interface, but they are displayed in the order "YCRCB, CIELAB, RGB" on the dialog window for some reason (thats just the way the author laid-out the dialog!);
- if you're using RGB images, you can ignore the gray settings (just set them to zero when your script invokes the plugin);
- "color threshold" values [0],[1] and [2] correspond to the 3 channels for whichever color-mode you choose; value [3] is not used;
- same for the "color low" values (ie. "softness" in the dialog).
As I said before, I tested this on Linux and it all seemed to work alright ..
In fact its probably best to try it with the Script-Fu Console first.
PostPosted: Fri Mar 27, 2015 10:28 am  (#11)
thanks, jontait2, now I'm more confident
PostPosted: Sun Mar 29, 2015 5:55 am  (#12)
Try this one dinasset. :)
I recompiled both 32 and 64 .The 64 bit works ok (no DOS popup) see screenshot post #1.
wavelet-denoise-0.3.1-Win32-jthack-noDOS.zip [23.93 KiB]
Downloaded 392 times
wavelet-denoise-0.3.1-Win64Bit-NoDOS.zip [70.34 KiB]
Downloaded 973 times
PostPosted: Sun Mar 29, 2015 11:01 am  (#13)
Thanks Rod,
replaced the .exe but unfortunately in win-32 the DOS pop-up is still there, both online and called, I'm sorry...
Edit:
I did the following attempts:
1-simply replacing the .exe with the new one and restarting Gimp: no success
2-removing also the new, restarted Gimp, checked it was no there (no "phantom" copy anywhere), then reintroduced, restarted Gimp: no success
3-the surgical remedy: removing the pluginrc file, restarted Gimp (which reloaded all the plug-ins): no success
sorry...
PostPosted: Sun Mar 29, 2015 12:58 pm  (#14)
to exclude the possibility that the problem is in my system:
might someone who is running Windows 7 - 32bits install and test the 32-bit version of this modified .exe plug-in ?
thanks
PostPosted: Sun Mar 29, 2015 1:55 pm  (#15)
jontait2 wrote:
@Rod
The window can't be minimized, but it can be closed which will then stop the plug in all together.
PostPosted: Sun Mar 29, 2015 2:04 pm  (#16)
thanks mackenzieh, so the problem is in the version itself, not in my pc
PostPosted: Sun Mar 29, 2015 3:28 pm  (#17)
Yeah, the problem is the version itself. I'm running the plugin on windows 7 64bit and I have that preview window as well. You can't minimize it; only close it. You're welcome, dinasset. :)
PostPosted: Mon Mar 30, 2015 12:18 am  (#18)
may I ask a question to jontait2 (or to whomever likes to answer)?
AFAIK the Lab (and CIELAB) representation has L represented by positive values 0-100
while a* and b* have both negative and positive values because they represent duopoles
(a* = green-magenta and b* blue-yellow)
hence my question:
in the denoise filter only positive values can be entered both in a* and b* fields;
does this mean that the value entered is applicable at the same time to:
- noise in green AND magenta (if entered into a* field)
- noise in blue AND yellow (if entered into b* field)?
and therefore it is not possible with CIELAB selected enter different noise limits for magenta and green? (or blue and yellow)?
thanks
PostPosted: Mon Mar 30, 2015 3:51 am  (#19)
Correct!
The filter denoises individual channels. If you select the CIELAB model, the channels are L*,a* and b*, by definition. Thats what the filter works upon. It does not re-interpret those channels as RGB or any other form, just as the selected model specifies. So if a certain pixel has an a* value of -43 before running the filter, it will still have a value of -43 afterwards, unless it gets altered by the de-noising. The filter does not change the hue per se, it just reduces localized variations in each channel.
If you want to to de-noise green and magenta separately you would have to use a different color model.
PostPosted: Mon Mar 30, 2015 4:07 am  (#20)
thanks jontait2!
this means also that:
- because G+M = total chroma as well as B+Y = total chroma, whichever value I enter into one of those it means "chroma noise reduction"
