It is currently Sun Aug 16, 2026 11:51 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3  Next
 Post subject: 3D from a single image.
PostPosted: Tue Mar 01, 2011 11:21 pm  (#1)
Tom just created a cool G'MIC preset to create 3D images from a single image. PC fixed a bug and now it works quite well. Thanks to both you Tom and PC. Very cool indeed. Below's a x-eye 3D result using that preset.
Image ref: http://www.fontplay.com/freephotos/seve ... 806-25.jpg
ref thread: http://www.flickr.com/groups/gmic/discu ... 154386744/
image flickr: http://www.flickr.com/photos/34520999@N05/5490994830/#
 Post subject: Re: 3D from a single image.
PostPosted: Tue Mar 01, 2011 11:57 pm  (#2)
That is perfectly awesome! I need to know how to do this!!
My Sigs = My Photos
PostPosted: Wed Mar 02, 2011 12:08 am  (#3)
Hey Mahvin; below is the settings that I used fyi. :)
PostPosted: Wed Mar 02, 2011 12:25 am  (#4)
Mine doesn't have the stereo base adjustment. Maybe I have a different version?
My Sigs = My Photos
PostPosted: Wed Mar 02, 2011 12:28 am  (#5)
Just downloaded the later one. Much better!
I still need to play with it.
My Sigs = My Photos
PostPosted: Wed Mar 02, 2011 1:07 am  (#6)
The curl is definitely stickout out PM; good result. Very cool preset this is going to be. :)
PostPosted: Wed Mar 02, 2011 2:41 am  (#7)
Yep, Lyle, I changed mine to adjust the image to 100%, too much pixel distortion/disintegration at 50%.
PostPosted: Wed Mar 02, 2011 4:14 am  (#8)
Nice - i didn't realize 1.4.8.2 was out now!
489 filters - wow!
PostPosted: Wed Mar 02, 2011 4:21 am  (#9)
I get a Preview Error with it. I copied the latest one and pasted it into my .gmic file.
PostPosted: Wed Mar 02, 2011 4:25 am  (#10)
try again should be a copy and paste issue
PostPosted: Wed Mar 02, 2011 4:31 am  (#11)
I've reached the point where I want to dump both files. I haven't kept up and everything that goes in them is scattered hither and yon. There are so many that have preview errors and don't work.
PostPosted: Wed Mar 02, 2011 4:32 am  (#12)
Paste it at the very bottom of your .gmic file exactly like this O.
#@gimp 3D Conversion : gimp_make3D, gimp_make3D_preview(1)
#@gimp : sep = separator()
#@gimp : note = note("Stereoscopic settings:")
#@gimp : Scene selector = choice("light motive","dark motive","landscape","center foreground","centerbackground","left foreground","right foreground","underwater")
#@gimp : Stereo base = float(50,0,200)
#@gimp : Depth control = float(0,0,100)
#@gimp : Flip left / right = bool(0)
#@gimp : Use indivial depth map = bool(0)
#@gimp : note = note("<small>To use this option your depth map must be placed below your image. Switch input layers to <i><b>Active and below</b></i>.</small>")
#@gimp : note = note("Image adjustment:")
#@gimp : Black & White = bool (0)
#@gimp : Stereo pair = bool (0)
#@gimp : Gamma compensation = float(1,0,4)
#@gimp : Color boost = float(1,0,4)
#@gimp : Red / cyan compensation = float(0,-255,255)
#@gimp : sep = separator(), Preview type = choice("Full","Forward horizontal","Forward vertical","Backward horizontal","Backward vertical")
#@gimp : sep = separator(), note = note("<small>Author : <i>Tom Keil</i>.      Last update : <i>2011/03/01</i>.</small>")
#@gimp : note = link("Filter explained here","http://www.flickr.com/groups/gmic/discuss/72157626154386744/")
gimp_make3D :
-repeat @# -l[$>] -if {$6==0} -to_rgb[0] --gimp_do_nothing[0]
-else -luminance[0] -to_rgb[0] --gimp_do_nothing[0] -endif
-if {$5==0}
-if {$1==0} --luminance[-1]
-gimp_channel_processing[-1] 1,{$3/25},0,0,0,0,100,256,0,0,0,2,0,0
-elif {$1==1} --luminance[-1] -negative[-1]
-elif {$1==2}
--gimp_linear_gradient[-1] 0,0,0,255,255,255,255,255,0,90,0,{100-$3}
-elif {$1==3}
--gimp_radial_gradient[-1] 0,0,0,255,255,255,255,255,1,$3,100,50,50
-elif {$1==4}
--gimp_radial_gradient[-1] 0,0,0,255,255,255,255,255,0,0,{100-$3},50,50
-elif {$1==5}
--gimp_linear_gradient[-1] 0,0,0,255,255,255,255,255,1,0,$3,100
-elif {$1==6}
--gimp_linear_gradient[-1] 0,0,0,255,255,255,255,255,0,0,0,{100-$3}
-elif {$1==7} --channels[-1] 0
-endif
-gimp_gaussian_blur[-1] 0,0,{{w+h}*0.00285},1,0,0,0
-else -rv[1,-1] -to_rgb[-1] -luminance[-1] -endif
-r[-1] 100%,100%,1,2 -s[-1] c -f[-1] 0 -n[-2] 0,$2 -a[-1,-2] c
-warp[-2] [-1],1 -rm[-1]
-if {$7==0} -s c
-if {$4==0} -rm[-1,-2,-6]  -mv[-1] 0 -a[-1,-2,-3] c
-else -rm[-3,-4,-5] -a[-1,-2,-3] c -endif
-else -if {$4==1} -rv[-1,-2] -endif
-r[-1,-2] 50%,50% -a[-1,-2] x -endif
-apply_gamma $8
-gimp_mix_lab 1,0,0,$9,0,0,$8,0,0,0,2,0
-if {$7==0} -gimp_mix_rgb 1,$10,0,1,0,0,1,0,0,0,2,0 -endif -endl -done
gimp_make3D_preview :
-gimp_split_preview "-gimp_make3D ${1--2}",$-1
#************END OF FILTER***************
PostPosted: Wed Mar 02, 2011 4:34 am  (#13)
Also if you like i can PM you my entire .gmic and .gmic_faves files. :)
PostPosted: Wed Mar 02, 2011 4:41 am  (#14)
I think that would work best. The file I copied and pasted doesn't look a bit like the one you posted the code to up there.
PostPosted: Wed Mar 02, 2011 4:52 am  (#15)
Sent the links to your PM O.
You probably grabbed the wrong files at flickr?
PostPosted: Wed Mar 02, 2011 4:54 am  (#16)
:lol i sent the first batch to me - woops :)
PostPosted: Wed Mar 02, 2011 5:17 am  (#17)
gimp_make3D :
-if {$5==0}
-elif {$1==2}
-elif {$1==3}
-elif {$1==4}
-elif {$1==5}
-elif {$1==6}
-endif
-if {$7==0} -s c
-apply_gamma $8
[/code]
I bet the Rod .gmic and gmic_faves file will work, but maybe not the code paste above
Maybe because may be just a question of how the code is displayed on the forum (even if Rod chosed the most safe option to post here )
Anyway all the lines i highlighted should have no return carriage or how you say in english(BTE ,how you say in english??), i mean what in yellow should be a single long line not splitted along more lines
that was exactly the problem i fixed
PostPosted: Wed Mar 02, 2011 5:30 am  (#18)
How come it works in mine though?
PostPosted: Wed Mar 02, 2011 6:04 am  (#19)
OK. I've updated G'MIC, the files Rod sent me did not work. I copied the code for 3D stereo Rod posted into my .gmic file and it's now working.
I was going to dump my faves file but I am giving it one more chance. The only one in my faves file that doesn't work is chiaroscuro. Here is how it is in my .gmic_faves file. There are no spaces or hard returns after it.
{GN- CHIAROSCURO}{Graphic Novel FX}{gimp_photocomix_booost2}{gimp_photocomix_booost2}{1}{4.36364}{10.4727}{5}{20}{0.12}{14}{0}{0.54}{2.9}{9}{0}{0.93}{1}{0.5}{0.54}{0.78}
PostPosted: Wed Mar 02, 2011 6:16 am  (#20)
As long as there are no white spaces between presets they should show in GMIC and work.
Unless you do not have Graphic Novel Effects filter installed.
