It is currently Fri Aug 21, 2026 8:06 pm
 Post subject: Arakne-path-shape-creator8
PostPosted: Mon Oct 12, 2015 5:03 pm  (#1)
New version of the plugin for create paths in Gimp, changes make incompatible to the previous version.
News:
Shapes grouped by category
Radioboxes and checkboxes in the interfaz
Help images for new shapes or more complex
New shapes
New shapes:
Moon
Foldables: box
Foldables: letter
Cloud
Arches: ojival y tudor
Radial ruler
Install
This version is not compatible with the previous, is mandatory delete the folder shapes and arakne-path-shape-creatorX.py.
Download Location is arakne-path-shape-creator8.zip
 Post subject: Re: Arakne-path-shape-creator8
PostPosted: Mon Oct 12, 2015 6:11 pm  (#2)
:bigthup That's cool thanks.
PostPosted: Mon Oct 12, 2015 6:30 pm  (#3)
Mackenzieh if you have a previous version delete all it's files and folders then install all the 'shape-creator8' files and folders All 'shape-creator8' files and folders should be installed in your user/plugins folder
PostPosted: Mon Oct 12, 2015 6:48 pm  (#4)
I got it to work.
PostPosted: Tue Oct 13, 2015 2:32 am  (#5)
Mackenzieh what I initially said was "This version is not compatible with the previous"
delete any previous shapes folder
Mackenzieh I'm glad you have it working :bigthup
PostPosted: Tue Oct 13, 2015 5:53 am  (#6)
Thank you Graechan for the update. :)
PostPosted: Wed Oct 14, 2015 2:23 pm  (#7)
Thanks for the update Graechan - I love this very useful script and used some of the new path/shapes for my glass ornament post.
PostPosted: Sat Oct 31, 2015 10:54 am  (#8)
I deleted previous shape folders and installed the new ones.
But when I want to use the shape creator I get this message
Is there something wrong in the plug-ins?
Can somebody help me?
Thanks in advance.
Ella
PostPosted: Sat Oct 31, 2015 11:16 am  (#9)
You need to remove one of the arakne-path-shape-creator8.py files.
PostPosted: Sat Oct 31, 2015 11:41 am  (#10)
I removed one of the files and restarted Gimp. But now I don’t find path under filter any more.
PostPosted: Sat Oct 31, 2015 12:33 pm  (#11)
You should remove all remnants of the shape creator (shapes folder, and all py, and pyc files) and re install fresh. :)
PostPosted: Sat Oct 31, 2015 1:21 pm  (#12)
I did follow your advice, Rod, but the same error message appears.
Probably I still did something wrong :(
PostPosted: Sat Oct 31, 2015 3:50 pm  (#13)
Did you remove all the py and pyc files containing the name "Arakne" ?
PostPosted: Sat Oct 31, 2015 7:54 pm  (#14)
Ella Louise if you have a previous version delete all it's files and folders then install all the 'shape-creator8' files and folders All 'shape-creator8' files and folders should be installed in your user/plugins folder.
Any previous Shapes Folder is not compatible with 'shape-creator8'.
PostPosted: Sun Nov 01, 2015 1:30 am  (#15)
Just as well I had to reinstall Arakne as I decided to check all my plugins permissions and half weren't ticked. I obviously don't do paths very often.
PostPosted: Sun Nov 01, 2015 7:49 am  (#16)
I deleted one more time the shape creator (also the folders and files of the previous version) and reinstalled the new one. But it still doesn’t work. The error message still appears.
For the moment I give up. I’ll try it later.
Thanks for the help, Rod and Graechan.
PostPosted: Sun Nov 01, 2015 9:11 am  (#17)
Ella Louise, if you are sure you don't have any previous files of Arakne-path, try to make a cleaner to eliminate possible remains and close everything. Then when you start your computer install the new Arakne version. :) Luck!
PostPosted: Sun Nov 01, 2015 9:40 am  (#18)
Which Windows and GIMP platform are you running? I am wondering if this newer version is not compatible with your platform/s.
PostPosted: Mon Nov 02, 2015 4:06 am  (#19)
@ Issabella, I did run Ccleaner after deleting the folders and files, without any succes. But thanks for the hint and your reaction :)
@ Rod, I have Windows Vista 32-bits and Gimp 2.8.14
PostPosted: Mon Nov 02, 2015 2:21 pm  (#20)
I have this shape,
seen in the attachment below.
That I've made using paths that helps me create emoticons.
It's basically a circle made using 5 pixels, 2 pixels, 1 pixel and 2 pixels, repeated 4 times.
To create a circle of 15x15 pixels.
I was wondering if this shape could be added to the shapes available to the Arakne-path-shape-creator plugin?
Or is there a way that I can add it to the plugin and be able to us it as needed?
