this is a résumé for addonCollectionManager:
a) in your /.gimp-2.8/plug-ins folder check you have: (after unzipping the attachment)
a1)addonCollectionManager-3.0.py
a2)addonCollectionManager.ini
b) in your /.gimp-2.8 folder check you have:
b1)brushes (initially empty) and brushes_storage (with your groups of brushes)
b2)fonts (initially empty) and fonts_storage (with your groups of fonts)
b3)gradients (initially empty) and gradients_storage (with your groups of gradients)
b4)palettes (initially empty) and palettes_storage (with your groups of palettes)
b5)patterns (initially empty) and patterns_storage (with your groups of patterns)
b6)scripts (initially empty) and scripts_storage (with your groups of scripts)
after Gimp start-up, you should find under Help:
- brushes sets...
- fonts sets...
- gradients sets...
- palettes sets...
- patterns sets...
- scripts sets...
any one of those activates the relevant "manager", to make your selection(s)
hope this can be of some help for you
addoncollmgr.7z [5.44 KiB]
Downloaded 307 times
