It is currently Thu Aug 20, 2026 12:05 am
 Post subject: Install beautify in Windows 7 with gimp 2.8
PostPosted: Thu Nov 19, 2015 4:27 pm  (#1)
Hello everybody, hope you can help me.
I've read other post about how to install the beautify but I've not been succesfull. I'm using windows 7 64 bits and gimp 2.8. I have downloaded the zip file from https:// github. c om/hejiann/beautify And I have readed that there should be some .exe files buy cannot find them. I also have tried copy paste some exe files I found in other post in plug in folder in C:\Program Files\GIMP 2\lib\gimp\2.0\plug-ins or in C:\Program Files\GIMP 2\share\gimp\2.0\ui\plug-ins but cannot get the beautify to appear in gimp. I've been trying two days and cannot. How should I do it? I really woul love to install it... thanks.
 Post subject: Re: Install beautify in Windows 7 with gimp 2.8
PostPosted: Thu Nov 19, 2015 4:41 pm  (#2)
You need to install the exe files in your user/username/gimp-2.8/plug-ins. Folder. The folders that come with the package go in the username/gimp-2.8 folder.
viewtopic.php?f=9&t=4811
USE the 64 bit version here if you have windows 64 bit with GIMP-2.8 64 bit installed.
http://www.aljacom.com/%7Egimp/Beautify ... ts-Win.zip
