It is currently Sat Aug 08, 2026 7:59 am
 Post subject: Submitting scripts and plug-ins to gimpscripts.com
PostPosted: Mon Feb 08, 2016 1:56 pm  (#1)
Normally if you contact Tux he will give you access to upload and edit your scripts. I thought this was already possible via the upload scripts and plug-ins link? Seems Tux may have the uploads set to be checked by a mod as to whether they be a safe file or not. Then a mod posts the files.
Why don't you send them to me via email and i will upload them to gimpscripts for you guys. PM me for my email contact.
In the email be sure to include all the info here
Script or Plug-in Title
Version
New submission or update
Author
Versions supported
Platform(s) Supported
Detailed Description of Script or Plug-in
License
GPLv2 GPLv3 CC BY CC BY-SA Freeware
Website or Support Link URL
Your Name (required)
Your Email (required)
NOTE: Executable's will only be excepted via ZIPPED container and will be thoroughly tested for virus and malware before submission. They must also include src files and 32 and 64 bit versions of the plug-in.
 Post subject: Re: Submitting scripts and plug-ins to gimpscripts.com
PostPosted: Mon Feb 08, 2016 6:25 pm  (#2)
Thanks Rod,
Check Your pms! ;) First request inbound!
(Solve if you can ... ;) )
PostPosted: Thu Jun 11, 2020 3:01 am  (#3)
The information contained above is out of date.
Before you ask a question about GimpScript, read this thread:
viewtopic.php?f=9&t=18437
PostPosted: Thu Jun 11, 2020 7:33 am  (#4)
I don't know who did it, but, saved the all those scripts or plugins in a big file the Gimp plugin registry:
https://github.com/pixlsus/registry.gimp.org_static Can we do the same? Just a thought.
PostPosted: Thu Jun 11, 2020 7:54 am  (#5)
That would be a great idea, Pocholo. :)
PostPosted: Thu Jun 11, 2020 10:15 am  (#6)
Is there a place we can host them where they'll remain in the cloud for all to use?
PostPosted: Sat Jun 13, 2020 1:50 am  (#7)
I took the first step: I downloaded these files (If I missed something, please add it to the list):
Updated list (as of 24-01-2017)
001 - 3d_Glassy_Web_Button.zip
002 - 3d-Extrusion.scm
003 - 3dscreenshot.scm
004 - Add_Gimp_Decor.zip
005 - Add_Gimp_Decor_2.zip
006 - Animated_Path_Stroke_Suite.zip
007 - Animatedfire.zip
008 - Animatedfirelite.zip
009 - Animated-Snow.zip
010 - Anim-Settings-Semiflatten.scm
011 - Antique Metal.scm
012 - Aurora-Logo.scm
013 - Autocolorize.scm
014 - Autohatchlayers.scm
015 - Base64-Gimp-Plugin-0.2.0.zip
016 - Bevel-Reflect-Logo.scm
017 - Bling-Text_Logov2.zip
018 - Blue Ice Rel7.zip
019 - Bp_Spiro_1.2.py
020 - Bumpy.zip
021 - Chisel.scm
022 - Chiseled-Steel-Text-V-1_Rd.zip
023 - Cobblestone-Mosaic.scm
024 - Colorful_Light_Effect_Gimp_2_8.zip
025 - Comix Text Bubble Rel5.zip
026 - Crayon-Text_Rd-V1.0.zip
027 - Crazyhedcut-Package.zip
028 - Crazytonemap-Package-2.zip
029 - Deigosecondlogic.zip
030 - Diego_Artistic_Crazyhedcut.zip
031 - Diego_Artistic_Davehilleffect.Py_.zip
032 - Diego_Artistic_Goldenmosaic-2.zip
033 - Diego_Artistic_Jamacksketch.zip
034 - Diego_Artistic_Mosaic_Stained_Glass_V2.zip
035 - Diego_Artistic_Mosaic_Stained_Glass_V3.zip
036 - Diego_Colours_Playwitrhatmosphere.Py_.zip
037 - Diego_Colours_Remove-All-But-Gray.7z
038 - Diego_Draw-Random-Drops.scm
039 - Diego_Enhance_Lylestyledetails.zip
040 - Diego_Enhance_Pseudohdreffect.zip
041 - Diego_Enhance_Rodstyledetails.zip
042 - Diego_Full-Dm-Gen-1.2.scm
043 - Diego_Glass-Frame-Effect-V1.1(Graechan).scm
044 - Diego_Globe-View.scm
045 - Diego_Mod_Lcs.7z
046 - Diego_Mosaic_Lyle_Style_2.zip
047 - Diego_Mosaic_Stained_Glass.zip
048 - Diego_Quantize_Gmic-1.7.9-Version-Texturizebyareabycolour.zip
049 - Diego_Quantize_Texturizebyareabycolour.zip
050 - Diego_Renderrain.Py_.zip
051 - Diego_Rendersnow.Py_.zip
052 - Diego_Stretch_Rgb_Colours.Py_.zip
053 - Double_Bump_Map.scm
054 - Double_Bump_Map26.scm
055 - Drawingfantasy-Package.zip
056 - Draw-Numbers.scm
057 - Electricity-Logo-Animated2-6.scm
058 - Embroidery-Stitcher_Rd.zip
059 - Envirologo.scm
060 - Enviromap.scm
061 - Exportandroiddrawable.scm
062 - Extrude-From-Path.scm
063 - Feu_D_Artifice_Fireworks_2_8.zip
064 - Figured_Glass_Source_Code.zip
065 - Filltrans.scm
066 - Flipandstick.scm
067 - Font Display Rel5.zip
068 - Font To Image Hose.scm
069 - Fp-Flowing-Sand-Anim.scm
070 - Fp-Kaleidoscope-Anim.scm
071 - Fp-Metalic-Ripple.scm
072 - Fp-Script-Fu-Grungy-Photo.zip
073 - Frost Crystals.scm
074 - Fu_Watermark.scm
075 - Fur Rel4.zip
076 - Gc Lens-Flare.scm
077 - Gc-Shadow.scm
078 - Glass-Text-V1-4.zip
079 - Glossy_Metal_3d_Text_By_Monsoonami_Gimp_2_8.zip
080 - Glossy_Stroke_3d.py
081 - Gmic Logos Script & Presets.zip
082 - Gradient Frame Rel2.1.zip
083 - Gradientextrapolate.Py.zip
084 - Gradient-Stroke.scm
085 - Grid-Based-Plugin-For-Gimp-Master.zip
086 - Gt-Bevel.scm
087 - Gurm_V0.8.4.zip
088 - H1bit_Export.Py_.zip
089 - Hatchselectionlayer.scm
090 - Hexmap.scm
091 - Highlight.scm
092 - Ice-Anything-Gimp-2.6_Rd.zip
093 - Ice-Anything-Gimp-2.8_Rd.zip
094 - Image Shine.scm
095 - Install_It.Py.zip
096 - Interleave-Layers-0.4.Py.zip
097 - Jaz_Diego_Wireframe_Gc_Ii-1.1.4.zip
098 - Kp24_Histo_Values.scm
099 - Kp24_Test_For_Duplicate_Scripts.scm
100 - Label_Arrows_From_Path.zip
101 - Lavaguts.scm
102 - Lava-Logo-V1-3.zip
103 - Layer_Names.Py.zip
104 - Layerfx.py
105 - Layerfx.scm
106 - Layerfx.2.8.py
107 - Layerutils.scm
108 - Line-Nova-Gt.scm
109 - Liquid_Water.0.4.scm
110 - Logo-Toolbox.scm
111 - Luminosity_Masks.scm
112 - Mats-And-Frames.scm
113 - Metallica! 2.2.zip
114 - Metallizefantasy-Package.zip
115 - Metal-Text-Rel-7.zip
116 - Midnightsepia.zip
117 - Mlbevelreflectv2_Linux_X32.zip
118 - Mlbevelreflectv2_Linux_X64.zip
119 - Mlbevelreflectv2_Mac.zip
120 - Mlbevelreflectv2_Source.C.zip
121 - Mlbevelreflectv2_Win32bit.zip
122 - Mlbevelreflectv2_Win64bit.zip
123 - Multi-Effect-Text-V1-1.zip
124 - Multiple-Layer-Actions.scm
125 - Multi-Replicate.scm
126 - Neon-Path-0.1.py
127 - New-Filter.zip
128 - New-Filter-To-Create-A-Funny-Mosaic-Based-On-Gmic-Shapeism.zip
129 - Newworldofcolours-Package.zip
130 - Oeuf.zip
131 - Offset_Path.scm
132 - Paintingonpaper-Package.zip
133 - Paste_Into_Selection.scm
134 - Path-Grid-0.0.zip
135 - Path-Inbetweener-0.0.Py.zip
136 - Path-Waves-0.2.py
137 - Pattern From Image.scm
138 - Perspective Advanced.scm
139 - Perspective_Path.Py.zip
140 - Perspective-Reflection-V0.2.scm
141 - Photo_Mosaic.py
142 - Picture Frame Rel3.zip
143 - Pinch_Source_Code.zip
144 - Plasticlogo.zip
145 - Plastic-Or-Glass.scm
146 - Psychedelic.scm
147 - Puzzler-Rel2.zip
148 - Rasterize.scm
149 - Reflectonponds.zip
150 - Reflex-Logo.scm
151 - Rel 5.2.zip
152 - Rendertexture1_3.py
153 - Rma_Selection_Blend.scm
154 - Rotatebrush.scm
155 - Rr_Make_Seamless.scm
156 - Rubiks-Cube-Rel-2.zip
157 - Rusted.scm
158 - Safari-2.6v2.zip
159 - Sample-Gradient-Along-Path.scm
160 - Save_All.zip
161 - Scale_Pattern.scm
162 - Scale2xplus.Py.zip
163 - Schrottie-Infrared_V1.2.scm
164 - Script-Fu-Interface.C-Mod-V1.0.zip
165 - Script-Fu-Interface-Mod-V1.0-Linux_X32.zip
166 - Script-Fu-Interface-Mod-V1.0-Linux_X64.zip
167 - Script-Fu-Interface-Mod-V1.0-Win_X32.zip
168 - Script-Fu-Interface-Mod-V1.0-Win_X64.zip
169 - Selection_Bevel.zip
170 - Sepia_Toning.scm
171 - Sf-Will-Wavetank_Gimp-2.8.zip
172 - Sg-Arrow-Stroke-Path.scm
173 - Sg-Calendar.scm
174 - Sg-Combine-Bg.scm
175 - Sg-Contour-Fill.scm
176 - Sg-Platonic-Calendar.scm
177 - Sg-Tooninator.scm
178 - Sg-Warptext.scm
179 - Shape-Path-0.91.scm
180 - Shiny_Painting.0.3.scm
181 - Shrek-Text.scm
182 - Smokin.zip
183 - Soapbubble2.6.scm
184 - Space Text.scm
185 - Sparkler-Animation-Effect.scm
186 - Split_Layer_Into_Tiles.Py.zip
187 - Ss-Split-Components_V1-0.scm
188 - Starry-Sky.scm
189 - Stepped Chisel.scm
190 - Stickit.scm
191 - Sweet_Candy_Text_Gimp_2_8.scm
192 - Symbol Display.scm
193 - Symmetry_Tile.zip
194 - Tiltshift.scm
195 - Traceoverflexi.Py.zip
196 - Transbg.scm
197 - Transfercolours-Package.zip
198 - Transpose_Tileset.Py.zip
199 - Ungroup_Grouplayer.Py.zip
200 - Update-Of-Mosaic_Lyle_Style.zip
201 - V0.01-Mystical.Free_.zip
202 - Vignette.scm
203 - Warhol Rel4.zip
204 - Waterdrops-Rel4.zip
205 - Whitebalancestretch.Py_.zip
206 - Whitebalancestretch2-1.1-Package.zip
207 - Wire-Art-Text.scm
208 - Woodenletters.Scm.zip
209 - Wrap-Map-0.4.py
210 - Wrought Iron.zip
211 - Xmas-Ornament-2.6.scm
212 - Zoom.scm
213 - Zoom-Selection.scm
Does anyone want to help in searching which scripts / plugins have already been updated for Gimp-2.10 (with listing number and site web address)?
PostPosted: Sat Jun 13, 2020 9:41 am  (#8)
I don't know if you will believe - but thanks to the kindness of one of the GimpChat members (who wants to remain anonymous for now) I already have the complete version of GimpScrpt from 24/01/2017.
The site contains 213 plugins.
I await the opinion of GnuTux (if he responds to my PM email) and Mike's position:
viewtopic.php?f=15&t=18388&p=251983#p251983
If nothing comes of it, I will be successively sharing files in this forum after upgrading to Gimp-2.10.20.
If anyone is willing to cooperate in this regard, please send me PM.
