It is currently Sun Nov 29, 2026 2:46 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page 1, 2, 3  Next
 Post subject: Mapfold effect scheme script.
PostPosted: Fri Apr 15, 2016 4:15 pm  (#1)
This is to create a similar effect like shown here: http://gimpchat.com/viewtopic.php?f=23&t=4439
I thought it would be fun to that effect into a script. So here it is.
before image:
after applying effect:
options for this plug-in:
script file:
MapFold.scm [4.15 KiB]
Downloaded 708 times
it'll be available under Script-Fu/Create New/Map Fold effect...
PS: script-fu experts... is there a way i can default the Shear Magnitude Y (the only adjustment i have right now) to a percentage of image height? if you know please show me how..right now i just have it default to 150..I think it would be friendlier if it starts off defaulting to a percentage of image height.
Last edited by trandoductin on Sat Apr 16, 2016 10:34 am, edited 2 times in total.
 Post subject: Re: Mapfold effect scheme script.
PostPosted: Fri Apr 15, 2016 4:17 pm  (#2)
Now that it's a script .. i kind'a hope to see Map Fold galore coming in :hehe
PostPosted: Fri Apr 15, 2016 5:02 pm  (#3)
because of fractional math, this script was creating 1 pixel artifacts on some different widths.. i just updated the script to get select whole pixels so that this artifact would not occur.
PostPosted: Fri Apr 15, 2016 5:18 pm  (#4)
Nice one Tin
PostPosted: Fri Apr 15, 2016 5:22 pm  (#5)
glad you like it.
PostPosted: Fri Apr 15, 2016 5:26 pm  (#6)
Trandoductin - thank you very much for this; now all we we have to do is consider how to get auto 'pop outs' in the script :hehe
PostPosted: Fri Apr 15, 2016 5:30 pm  (#7)
pop outs are probably too advanced since you probably have to do manual selection and stuff. i don't think i can automate that
PostPosted: Fri Apr 15, 2016 5:34 pm  (#8)
Tin - I was just joking but I will have a play now I have downloaded your script. Again thanks.
PostPosted: Fri Apr 15, 2016 5:40 pm  (#9)
just for fun... i cut out the word Victoria before using the effect and then used a colorful image as background.
PostPosted: Fri Apr 15, 2016 6:52 pm  (#10)
Heck of lot easier than doing it by hand. Great script!!!
PostPosted: Fri Apr 15, 2016 6:53 pm  (#11)
Works very well Tin ...
PostPosted: Fri Apr 15, 2016 6:56 pm  (#12)
trandoductin! Great work, wow! Thank you.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Fri Apr 15, 2016 6:57 pm  (#13)
Omg wow, look at that! You're amazing.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Fri Apr 15, 2016 7:02 pm  (#14)
keep em coming :hehe
PostPosted: Fri Apr 15, 2016 7:18 pm  (#15)
Very clever, OMG.
PostPosted: Fri Apr 15, 2016 7:27 pm  (#16)
This is a picture of my desk.
I just changed the drop shadow a bit, but nothing more.
Also my camera added a color cast to the image,
because my walls aren't that color.
They're more like a beige or sand color.
PostPosted: Fri Apr 15, 2016 7:45 pm  (#17)
Ok I've lost my mind.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Fri Apr 15, 2016 8:42 pm  (#18)
I almost ruined it! I accidentally saved it as a jpg, and had to get rid of the black background and make my own shadow. This time I remembered to make it a .png! Decided to make a folder of different relatives.
PostPosted: Fri Apr 15, 2016 9:11 pm  (#19)
Last before bed...
PostPosted: Fri Apr 15, 2016 9:18 pm  (#20)
well this is different... i never even thought of an image other than rectangle or square.
