It is currently Sun Nov 22, 2026 9:19 pm
 Post subject: Revisiting 3D spherical Text
PostPosted: Mon Apr 18, 2016 12:57 am  (#1)
Tutorial written by Wallace:
viewtopic.php?f=10&t=13008
Script for Text written by Trandoductin: viewtopic.php?f=9&t=13004&hilit=3d+spherical+text+wallace
I thinks the effects from this script, and the instructions from the tutorial were easy to follow and gives a very pleasing image. I wanted to do it again as it has been awhile. Thanks again, Tin and Wallace for your efforts.
 Post subject: Re: Revisiting 3D spherical Text
PostPosted: Mon Apr 18, 2016 1:07 am  (#2)
Oh my, is that nice. I will definitely give it a go when I get a chance.
PostPosted: Mon Apr 18, 2016 1:09 am  (#3)
You're welcome and your image looks really nice Pat625.
I'm happy that you had fun creating it.
PostPosted: Mon Apr 18, 2016 12:14 pm  (#4)
Very nice Pat. :bigthup
PostPosted: Mon Apr 18, 2016 3:40 pm  (#5)
I'm going to have a lot of fun with this one, thanx guys
PostPosted: Mon Apr 18, 2016 5:20 pm  (#6)
:kpix
PostPosted: Tue Apr 19, 2016 5:34 pm  (#7)
I've only tried this tut about three times but every time I end up with only a blur...can't see the letters at all. Does the colour of the letters make a difference and font? Do you put the original sphere on top of the blurred ones?
I might be slow but cannot get it to work :( :oops:
PostPosted: Tue Apr 19, 2016 5:46 pm  (#8)
You must put the original first spherical layer on top of all the motion blurs.
PostPosted: Tue Apr 19, 2016 6:37 pm  (#9)
:grphug
Yes Pat625, you're correct.
All the work should be done on duplicate's of the original spherical zoom layer.
Keeping the original spherical zoom layer as the top layer.
I urge you all,
to experiment with each and every step of this tutorial,
to try and make it your own.
To produce an image both pleasing to yourself as well as others.
PostPosted: Wed Apr 20, 2016 5:40 am  (#10)
Thanks Pat and Wallace
Now I will try again
Felt it could have been better
PostPosted: Wed Apr 20, 2016 6:37 am  (#11)
You Did It!!!
PostPosted: Wed Jun 11, 2025 9:30 am  (#12)
Can someone attach this script here please? :)
PostPosted: Wed Jun 11, 2025 11:04 am  (#13)
This one ????
zoom.scm [7.4 KiB]
Downloaded 1524 times
PostPosted: Thu Jun 12, 2025 12:58 am  (#14)
rich2005 wrote:
This one ????
Yes! Thank you sir. :tyspin
Been a task getting back all my favorite filters to create custom fonts. Appreciate your help Rich.
