It is currently Sat Aug 22, 2026 7:53 am
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2, 3  Next
 Post subject: Random Alphabet background generator.
PostPosted: Sat Apr 23, 2016 10:27 pm  (#1)
this topic gave me an idea http://gimpchat.com/viewtopic.php?f=22&t=13940
So i did a script that generates random abc's with random color.
Random_Font.scm [2.11 KiB]
Downloaded 453 times
will be available under Script-Fu/Create New/random font (although i probably should have called it random characters or something)
here is the option window for the script
I'll randomly create number of characters specified by options and random color of the font chosen and move it to a random spot on the image. You'll end up with many layers, just "Merge Visible Layers" to flatten it afterwards and use it as background to any shape you like like a large letter.
like this
TinT
 Post subject: Re: Random Alphabet background generator.
PostPosted: Sat Apr 23, 2016 10:51 pm  (#2)
Playing with it now. Cool!!!!
PostPosted: Sat Apr 23, 2016 11:05 pm  (#3)
First try.
PostPosted: Sat Apr 23, 2016 11:18 pm  (#4)
Fontster Mash
I was working on the tab, late one night
When my eyes beheld an eerie sight
For my fonts from the tab, began to rise
And suddenly to my surprise
They did the mash, they did the fontster mash
The fontster mash, it was a graveyard smash
They did the mash, it caught on in a flash
They did the mash, they did the fontster mash...
Mashed & abridged from Bobby Pickett's "Monster Mash"
PostPosted: Sat Apr 23, 2016 11:18 pm  (#5)
Odinbc wrote:
Fontster Mash
It was a smash.
PostPosted: Sun Apr 24, 2016 12:54 am  (#6)
That's a phat looking B :hehe
TinT
PostPosted: Sun Apr 24, 2016 2:04 am  (#7)
Thanks Tran
my first THREE
PostPosted: Sun Apr 24, 2016 2:31 am  (#8)
It is good but it would have been more useful if the user were a given a control over the choice of alphabet or 'word'.
PostPosted: Sun Apr 24, 2016 3:12 am  (#9)
Did it on a transparent layer, merged layers then mapped to sphere.
PostPosted: Sun Apr 24, 2016 3:45 am  (#10)
for some reason transparent goes black in G'MIC :(
Image white background
I ran the script twice before path - shape creator
PostPosted: Sun Apr 24, 2016 5:19 am  (#11)
Did another using a Carebears font.
PostPosted: Sun Apr 24, 2016 7:21 am  (#12)
Is there any chance of modifying script to only add letters within a selection
PostPosted: Sun Apr 24, 2016 7:51 am  (#13)
Thank you so much Tin for a new toy to play. :tyspin :coolthup
PostPosted: Sun Apr 24, 2016 8:05 am  (#14)
And this transformation.
PostPosted: Sun Apr 24, 2016 10:10 am  (#15)
Sounds like you and Rashid on on the same train.
Maybe a script that does this and an Alpha to logo.
PostPosted: Sun Apr 24, 2016 10:55 am  (#16)
I guess if the selection was rectangle or square but i wouldn't know how to limit it to an odd shape selection since all i do now is move (translate) it to a (rand width) (rand height).
TinT
PostPosted: Sun Apr 24, 2016 10:57 am  (#17)
Wow so many beautiful creations... I am excited. :mrgreen:
TinT
PostPosted: Sun Apr 24, 2016 9:37 pm  (#18)
Issabella..that is COOL!
PostPosted: Mon Apr 25, 2016 2:05 am  (#19)
(if (> (car (gimp-selection-value image (rand width) (rand height))) 0)) you are inside the selected area regardless of it's shape
PostPosted: Mon Apr 25, 2016 2:19 am  (#20)
cool. thanks
I'll look at my script tomorrow and change it so that it'll randomize inside selection and maybe even cut it to selection too.
TinT
