It is currently Sun Aug 23, 2026 5:20 pm
 Post subject: Simplifying the scripting process
PostPosted: Wed Apr 27, 2016 10:57 am  (#1)
I recently had the idea of writing my scripts (.txt files) in situ in the script folder itself.
In the scripts folder I highlighted everything and using properties set everything to hidden. In what now looks like an empty script folder, I placed one image for testing purposes and a template .txt file.
Previously when working in a folder in My Documents the process was
Modify script
Save script with different name
Save as .scm file
Drag and drop .scm file into script folder
Click into script folder
Delete previous .scm version
Click back into working folder
Test in gimp
Working directly in the script folder the process is
Modify script
Save as .scm file
Test in gimp
This saves me the constant dragging, dropping and clicking back and forth between folders. To date there have been no adverse effects, that I’ve noticed.
I wonder what other script writers do to make their script processing easier, care to share
Steve
 Post subject: Re: Simplifying the scripting process
PostPosted: Wed Apr 27, 2016 11:18 am  (#2)
Even with your simplified process I don't understand why you're doing all this re-naming, copying, deleting etc :?:
Let's start with "Why are you creating files with a .txt extension?"
And if you want to keep the folder-clutter down, create a new "development" folder somewhere, add it to the list of Folders for scripts in GIMP preferences and work there.
Kevin
PostPosted: Wed Apr 27, 2016 11:31 am  (#3)
paynekj wrote:
Even with your simplified process I don't understand why you're doing all this re-naming, copying, deleting etc :?: Kevin
I like to save previous versions of the .txt files, if as I often do I go down a dead end with a script I can go back and try another route
paynekj wrote:
Let's start with "Why are you creating files with a .txt extension?"Kevin
I write all my scripts in a .txt file, before renaming as a .scm file, I don’t know any other way
paynekj wrote:
And if you want to keep the folder-clutter down, create a new "development" folder somewhere, add it to the list of Folders for scripts in GIMP preferences and work there.Kevin
Thanks Kevin, I will look into this
PostPosted: Wed Apr 27, 2016 11:47 am  (#4)
I just use notepad++ to edit the .scm file directly in the scripts folder.
Then I just save.
And test in Gimp.
I like notepad++ because it recognizes many file formats..so you see here it highlights many of the keywords in blue
and it highlights matching brackets when you move your cursor to the front or the end of bracket. if there are multiple brackets next to each other it'll highlight the one you're at the end of.
and it does a pretty good job at auto complete words like if you had many variable names and don't remember them this helps
Image.
TinT
PostPosted: Wed Apr 27, 2016 12:10 pm  (#5)
I just wish someone would come up with a nodal gui to create scripts like Mathmap did. :)
PostPosted: Wed Apr 27, 2016 1:33 pm  (#6)
Don't worry lylejk, soon they'll have software that speaks to you and asks what kind of effect you want then it does it and keeps asking you to tweak it to your liking at least that's what i am hoping for.
TinT
PostPosted: Wed Apr 27, 2016 2:50 pm  (#7)
Then I just save.
And test in Gimp.
[ Image ].
Thanks for the heads up on notepad++ :bigthup , looks great
PostPosted: Wed Apr 27, 2016 2:58 pm  (#8)
Ok obviously there was another way, which I have now found :oops: :oops: :oops: (x1000) :hehe
I see now the .txt files are redundant
