It is currently Tue Aug 11, 2026 5:18 am
 Post subject: Make a pdf file smaller? : )
PostPosted: Sat Mar 26, 2011 6:36 pm  (#1)
Hello!
I am trying to figure out how to reduce the size of a pdf file in order to email it.
I am editing photos and graphics in gimp and then inserting them into an open office draw document.
I converted it into a pdf by printing it on the cutepdf converter. There is also a option within open office to export to pdf
I have emailed the file and no one can get it because it is too big.
I dont see any option for decreasing the file size.
Do I have to create a zip file? If so, could you point me in the directions of a link with instructions?
Any help will be greatly appreciated!!!
Thanks
:gimp :tyspin :tyspin :) FlipFlop
 Post subject: Re: Make a pdf file smaller? : )
PostPosted: Sat Mar 26, 2011 6:38 pm  (#2)
Are you using Linux or Windows?
I use cups-pdf in Ubuntu and never seem to have very large file sizes.
PostPosted: Sun Mar 27, 2011 4:48 am  (#3)
Doesn't RIOT handle PDF files - i cant remember. ??
EDIT: Nope it doesn't -- sorry
Found this though -
http://www.websiteoptimization.com/speed/tweak/pdf/
PostPosted: Sun Mar 27, 2011 6:31 am  (#4)
The pdf settings make a big difference. A quick test
Using libreoffice(openoffice), with two 1800x2500 jpegs (about 1.5 MB each) on one page. Then exporting as a pdf.
The default setting with jpeg= 90% & 300 dpi produced a pdf = 1.8 MB
with jpeg= 80% & 300 dpi produced a pdf = 1 MB
with jpeg= 80% & 150 dpi produced a pdf = 230 kB
From memory cute pdf might be even worse, maybe have a default dpi of 600 - you need to check the settings.
PostPosted: Sun Mar 27, 2011 6:45 am  (#5)
I use PDF creator for windows which is free and i always have small files after they are finished.
http://www.pdfforge.org/
PostPosted: Mon Mar 28, 2011 12:03 pm  (#6)
Whatever big is your PDF zipping will dramatically shrink the size...and use .7zip format will shrink file size much more then standard .zip
in case 7zip is the tool for the trade (not the only but a good one )
PS. Gmail seems support very huge attachment
