It is currently Sun Aug 23, 2026 8:29 pm
 Post subject: Create New Gradient Along Path (python fu script).
PostPosted: Thu May 12, 2016 5:29 pm  (#1)
Will allow you to quickly create a gradient by sampling color values of an active layer along the active path.
To run the script just have the layer you want to grab colors out of selected and have a path active (some simple path drawn).
The script will divide the path (approximately) into number of segments and sample color values to use for new gradient.
After the script runs, you should have a new gradient created with the name you have specified as input for the script.
Will be available under <Image>/Tools/Create New Gradient Along Path...
create_new_gradient_along_path.zip [2.51 KiB]
Downloaded 362 times
2nd version allows STRAIGHT LINE equal distance sampling
This was an idea suggested by PegLeg44. At least that's way i understood him (hopefully I am right).
This is what the options look like for the script.
I said approximately because as you can tell below it's not exact equal distance along the path but it's pretty close.
for a 5 segment gradient
for a 25 segment gradient
TinT
 Post subject: Re: Create New Gradient Along Path (python fu script).
PostPosted: Thu May 12, 2016 5:45 pm  (#2)
Have yet not tried it but a great idea. Does it differ from the one in G'MIC?
PostPosted: Thu May 12, 2016 5:53 pm  (#3)
I didn't know there was one in GMIC so i don't know :oops:
TinT
PostPosted: Thu May 12, 2016 6:12 pm  (#4)
Thank you trandoductin! Just downloaded. :bigthup
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Thu May 12, 2016 7:04 pm  (#5)
Thank you for giving it a try :yes
TinT
PostPosted: Thu May 12, 2016 7:10 pm  (#6)
I already have a script installed made by Rob A, that does this same thing.
PostPosted: Thu May 12, 2016 8:52 pm  (#7)
I didn't know that Wallace.. :hehe
TinT
PostPosted: Thu May 12, 2016 9:05 pm  (#8)
Okay so I think PegLeg44 wants something that calculates from a straight path.
Currently this script treats it as a Cubic Bezier Curve so the sampling points are like this
for a 10 segment gradient.
So from a straight path, we should just simple calculate equal distance like this
So now i've added an option you can choose "YES" to calculate like the 2nd image above (with equal distance) and not like Bezier Curve like 1st image.
This is the second version of this script.
create_new_gradient_along_path.zip [2.78 KiB]
Downloaded 328 times
TinT
