It is currently Sat Aug 22, 2026 5:20 pm
 Post subject: Create Paths Experimentation (don't know if a script exists already).
PostPosted: Sun Jul 10, 2016 2:46 pm  (#1)
I don't know if a script for this exists or not, but i just did it just for fun.
create a path, name it "from"
duplicate the path, name it "to" and deform it however you like as long as the path has the same number of points (control points) as the first path("from" path).
Then run this python-fu plug-in (available under Image/Python-Fu/Create Paths between from and to...)
create_paths_between_two_paths.zip [1.57 KiB]
Downloaded 149 times
It'll do linear interpolation of the control points and create number of paths between these 2 "from" and "to" paths.
example
start with something like this
and end up with something like this, at which point you can use these paths to draw stuff and animate them or anything.
TinT
 Post subject: Re: Create Paths Experimentation (don't know if a script exists alread
PostPosted: Sun Jul 10, 2016 3:13 pm  (#2)
That seems much like the path-inbetweener-0.2.py by Ofnuts,
which does pretty much the same thing
PostPosted: Sun Jul 10, 2016 3:35 pm  (#3)
well look at that..it already exists. :hehe
TinT
PostPosted: Sun Jul 10, 2016 3:42 pm  (#4)
Yes.
Ofnuts pretty much has any path related script or plugin on locked down,
with his Gimp Path Tools.
You can easily find his path tools by searching for,
Gimp Path Tools by Ofnuts.
PostPosted: Mon Jul 11, 2016 11:44 am  (#5)
Just downloaded trandoductin and thank you for showing how to use the script. Thank you Wallace for advising about, Ofnuts plugin. I have plugins that I really don't know how to use so will play with both.
McGimp 2.8.14
G'mic 1.6.5
