It is currently Sun Aug 23, 2026 9:31 am
 Post subject: Redfield/Fractalius Photoshop Plug-in
PostPosted: Wed Aug 03, 2016 11:31 am  (#1)
Here's the Photoshop Plug-in Redfield/Fractalius (No Watermark) by James Ward.
You can pick it up by using the Gimp Chat topic link below.
viewtopic.php?f=11&p=197827#p197827
Note:
The PSPI plug-in needs to be installed and configured to use Photoshop plugins in Gimp.
 Post subject: Re: Redfield/Fractalius Photoshop Plug-in
PostPosted: Thu Aug 04, 2016 2:08 pm  (#2)
You've done it now Wallace, I'm going to be getting my little Vaio with Windows (God knows what version), installing Gimp and all these plugins I can't get to work on a Mac. Can't wait to see my family's face when I'm sitting with two machines at the same time :roll:
Thank you for the link! :tyspin
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Thu Aug 04, 2016 2:25 pm  (#3)
my first try
thanks Wallace !
PostPosted: Thu Aug 04, 2016 2:39 pm  (#4)
Beautiful work guys, thank you. Dalia, it's up to you, I've tried W8 and W10 - I'm back to W7, no hassle.
By the way what does configure mean? (I'll understand if it's beyond me at this stage, I'm back at school in September, the oldest guy in class!)
PostPosted: Thu Aug 04, 2016 9:25 pm  (#5)
:hehe
You're welcome Dalia.
my first try
thanks Wallace !
No problem. :bigthup
You need to setup a folder to put the Photoshop plug-ins into.
This folder is where PSPI will look for the plug-ins.
First create a folder to place the photoshop plug-ins into.
I created a folder inside my Gimp User Directory and named it Photoshop Plug-In.
You can create this folder wherever you like and name it as you see fit.
Place the PSPI plug-in into you Gimp User Plug-ins folder.
My User Plug-ins folder is located at: C:\Users\Wallace\.gimp-2.8\plug-ins
Once the PSPI plug-in has been installed.
Open it to setup the PSPI search path.
The dialog you see below will appear.
PostPosted: Fri Aug 05, 2016 1:50 am  (#6)
Note:
Wallace, how do you make your GIMP layer icons look bigger?
:oops:
PostPosted: Fri Aug 05, 2016 9:18 am  (#7)
:oops:
I have the preview size set to Gigantic.
PostPosted: Fri Aug 05, 2016 9:50 am  (#8)
Okay before I go pulling out my Vaio, I thought I'd run the G'MIC > Artistic > Rodilius. dinasset, I hope you don't mind that I used your beautiful image to run it but I wanted to see how different the result would be. While I love the results achieved with the Fractalius, Rodilius does a pretty good job as well so for Mac users it is an option.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Fri Aug 05, 2016 11:20 am  (#9)
very good Dalia, much better than my attempt on Fractalius
PostPosted: Fri Aug 05, 2016 8:21 pm  (#10)
You are too kind dinasset - your result is the way it should look.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Fri Aug 05, 2016 8:40 pm  (#11)
Wallace, my apologies as well for using your image just to try out GMIC > Rodilius. I think it's pretty close to Fractalius. The Vaio will stay tucked away for a while yet ;)
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Fri Aug 05, 2016 8:51 pm  (#12)
I can't deny what I see and it looks pretty good. :bigthup
PostPosted: Fri Aug 05, 2016 10:28 pm  (#13)
Wallace the Fractalius Photoshop Plug-in has always ran very smoothly and offers more options than GMIC
PostPosted: Sat Aug 06, 2016 3:08 am  (#14)
Yes I agree.
PostPosted: Sat Aug 06, 2016 4:45 am  (#15)
Once again, thank you Wallace for your kindness and help, priceless -in Peace RJKD
PostPosted: Sat Aug 06, 2016 5:03 am  (#16)
Sure no problem. :bigthup
PostPosted: Sat Aug 06, 2016 11:49 am  (#17)
Totally agree with you Graechan that the Photoshop Plug-in's results are superior to our Gimp's GMIC - for us Mac users though it allows us to participate. Your result with Fractalius is beautiful!
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Sun Aug 07, 2016 12:43 am  (#18)
previously i used neon light, this image was done with the lines setting
PostPosted: Mon Aug 08, 2016 1:25 am  (#19)
