It is currently Fri Aug 14, 2026 6:08 pm
 Post subject: Ascii Art *GIMP Script Question* NOT ARTWORK!
PostPosted: Mon Apr 04, 2011 3:45 pm  (#1)
Ok, so I tried to compile bascii pre alpha, doing so successfully, but there are no instructions anywhere I can find, on how to run it. It isn't registered in the GIMP menus as far as the c file shows. The sourceforge site is like bare bones. It's not critical, but apparently the author thought we were all mindreaders. Joy!
Anyhow, I know GIMP converts files to ascii via saving files to txt. The bigger question is, why doesn't GIMP allow for you to view your ascii/text file afterwards? This seems rather odd. Sure, when I open the txt file in an editor I get a very large page which my screen won't allow me to see in full. Surely there is a better way and I am just not aware of it?
I thought I was being savvy, by copying the text file and pasting it as a new image into gimp, and all that does is gives you a transparent image with the text image area in a solid white color. I was expecting to see black text on white background. Any information appreciated. :)
 Post subject: Re: Ascii Art *GIMP Script Question* NOT ARTWORK!
PostPosted: Mon Apr 04, 2011 4:37 pm  (#2)
You will find it in save as dialog Mahvin - although every time i try to use it it kills the plug-in.
Basically you just open an image and save it as BACSII - a dialog pops up asking which font and some other stuff, then you click okay and hope it works... :lol
Be nice if you could get it to work and tell me how you did it. :)
PostPosted: Mon Apr 04, 2011 4:41 pm  (#3)
I just use ASCIIGen. It's now open source too (though it's now a .NET program; still have his original non-.NET program, but the .NET version is much better). :)
PostPosted: Mon Apr 04, 2011 4:44 pm  (#4)
There's your answer, Rod, lol. Jeez!
PostPosted: Mon Apr 04, 2011 4:53 pm  (#5)
Here is an image of the dialog i get. I don't know if it will help or not though.
Lyle can that program be called with shellout?
PostPosted: Mon Apr 04, 2011 4:55 pm  (#6)
I get the menu, Rod. It's just after I make the selection and press OK, I get the error about file-bascii-save.
PostPosted: Mon Apr 04, 2011 5:04 pm  (#7)
I figured that mahvin you Ninjafied my post :lol
PostPosted: Mon Apr 04, 2011 5:09 pm  (#8)
Searching under ASCIIGen results in all kinds of sites, none of which have open source files. One sourceforge site for ASCIIGen was blank.
PostPosted: Mon Apr 04, 2011 5:12 pm  (#9)
http://ascgendotnet.jmsoftware.co.uk/download
PostPosted: Mon Apr 04, 2011 5:26 pm  (#10)
Thanks Lyle the NET version does work better. :)
PostPosted: Mon Apr 04, 2011 5:34 pm  (#11)
Check out this weird but sort of cool result when I paste a text copy (picture of me as a txt file) into a blank white background image in GIMP. It's sort of cool and easy, but in its natural form, the layer is actually a solid white image.
PostPosted: Mon Apr 04, 2011 5:43 pm  (#12)
Rod gave you the main good page of the Mahvin; below's the Sourceforge linker. :)
http://sourceforge.net/projects/ascgen2/
PostPosted: Mon Apr 04, 2011 5:46 pm  (#13)
Lyle have you tried it with Shellout yet?
PostPosted: Mon Apr 04, 2011 5:46 pm  (#14)
That is pretty cool. :)
PostPosted: Mon Apr 04, 2011 5:57 pm  (#15)
Unfortunately it can't be compiled in Linux, or even used with mono.
PostPosted: Mon Apr 04, 2011 6:03 pm  (#16)
Always used copy/paste if I did any GIMPy things with it, but I've not tried to Shellout yet. Just noticed they had updated it since I last installed it back in Dec. 2009 (only a few weeks after I upgraded to Win7). Might download and try the current version later. The one in 2009 still works fine though. :)
edit: misspoke; the website updated. I still have the current version. lol
PostPosted: Mon Apr 04, 2011 6:46 pm  (#17)
Works in shellout. :)
PostPosted: Mon Apr 04, 2011 6:49 pm  (#18)
Man; if I had the ability to give Rob some serious dough, I would. Shellout really puts GIMP on steroids. Be cool if someone attempts to Shellout to PS (I won't though; lol). :)
PostPosted: Mon Apr 04, 2011 6:57 pm  (#19)
You just have to go through all the saves in ASCII and then save it in the location of the ShelloutTemp file in
C:\Documents and Settings\user\local settings\temp
PostPosted: Mon Apr 04, 2011 7:01 pm  (#20)
I have and it does work LOL
but it takes mine too long to load so i use XnView instead or Paint Dot Net now that i know it can run 8bf filters.
I wish i could figure out how to shellout to Filter Forge - then i think i would just need it. :)
Tried everything i know though, even moving dll files about... no go.
But believe it or not Paint Dot Net runs Filter Forge :lol ... go figure
