It is currently Fri Aug 21, 2026 8:07 pm
 Post subject: Select guides surrounding active path points (py. script)
PostPosted: Fri Sep 23, 2016 3:27 pm  (#1)
I am not entirely sure how useful this is but I thought i'd do it for fun.
Release 1. (available under <Image>/Image/Guides/Select Guides Surrounding Active Path Points)
guides_select_from_path_points.zip [1.95 KiB]
Downloaded 231 times
Instructions.
Have an image filled with guides
Now draw a path (could be just points without out lines by holding down the Shift key while clicking away in middle of rectangles that you want to select)
Now run script.
And you'll see the rectangles surrounding your active path's points will be selected (shown in lighter rectangles).
When you draw the path you don't have to use Shift clicks to draw just points, it can be a regular path (but only the points will be used). For example you can draw a path that looks like this.
And after you run script, You'll get a selection that looks like this
Let me know what y'all think :hehe
TinT
 Post subject: Re: Select guides surrounding active path points (py. script)
PostPosted: Fri Sep 23, 2016 3:33 pm  (#2)
I made it so that it also works on a Selection bounding box.
For example if you have a selection like below
After running script, you'll get something like this.
TinT
PostPosted: Fri Sep 23, 2016 4:00 pm  (#3)
You're amazing my friend. :bigthup
I have no idea what I would do with this but I admire your persistence.
PostPosted: Fri Sep 23, 2016 4:50 pm  (#4)
That's why i said I am not entirely how useful it is :hehe
TinT
PostPosted: Fri Sep 23, 2016 4:56 pm  (#5)
Odin, does Tran's brain ever sleep?
PostPosted: Fri Sep 23, 2016 4:57 pm  (#6)
Thanks Tin.
Very practical to create geometric patterns.
The first idea for the use of:
PostPosted: Fri Sep 23, 2016 6:03 pm  (#7)
Probably not, the brain never sleeps it just gets disconnected.
The older I get, the more often that happens to me even when I'm awake.
The older I get, the more often that happens to me even when I'm awake. ;)
PostPosted: Fri Sep 23, 2016 6:39 pm  (#8)
It's too late to try and put the genie back in the bottle, so we'll just take the random scripts and figure out how to make them useful. Since you made a point of using points, my brain kicked into high gear asking, why just guides? What if you could also use points selected on various layers, areas within x amount of pixels to create selections of various kinds (squares, rectangles, ellipses, or circles) and add the ability to number those selections? I tend to create images for tutorials that add steps (in numerical value) on screenshots. Step 1, click here, Step 2 do this and that and the other, Step 3.... this sort of script would be ideal for that.
EDIT: There is already a script that does this and it is found here:
http://registry.gimp.org/node/25086?des ... node/25086
PostPosted: Fri Sep 23, 2016 9:28 pm  (#9)
I was in the process of posting a script for this when i saw your EDIT.
I tried the script you mentioned and well mine is a bit different giving a little more control since it creates separate layers for fill and numbers so you can apply effects if you really wanted to .... hopefully you try mine out too and make your own decision on which one you like more
it's here --> http://gimpchat.com/viewtopic.php?f=9&t=14607
TinT
PostPosted: Sat Sep 24, 2016 12:12 am  (#10)
It makes the selection circles and then stops dead in its tracks. Never mind, it was user error. I had messed up the path by altering it with another script before running your script. Leaving the path alone allowed the plugin to work properly. Just one small issue: the numbers don't center in the selections. Having them as layers allows me to make adjustments, although I would prefer not having to do that.
PostPosted: Sat Sep 24, 2016 12:39 am  (#11)
Numbers don't center in selections?
I put them dead center in circles.
From my trials they're all centered, can you show me an example image of how it's not centered?
EDIT: I think I know what you mean by they're not centered.
It's the text layer (the number) when it's created it's got spaces around the number and the surrounding space isn't even all the time so that's why.
I should be able to make it dead center with a few steps of manipulation.
Will Release #2 soon.
TinT
PostPosted: Sat Sep 24, 2016 1:08 am  (#12)
Hi Mahvin.
The next version mark-number-circles.scm - RMA_label_points.scm RobA.
https://www.cartographersguild.com/showthread.php?t=17514
The best not only to tutorials. :)
Options are:
- Method (Numeric - 1,2,3, etc.; Alphabet - A, B, C, etc; Custom)
- Custom (comma separated list of labels)
- Font (picker)
- Text Size
- Outline (None, Hard, Soft, Circle)
- Outline Size.
PostPosted: Sat Sep 24, 2016 1:28 am  (#13)
Wow that one looks super advanced. :hehe
TinT
PostPosted: Sat Sep 24, 2016 4:13 am  (#14)
PostPosted: Sat Sep 24, 2016 2:06 pm  (#15)
:hehe You enjoy clicking paths way too much
TinT
PostPosted: Sat Sep 24, 2016 4:38 pm  (#16)
downloads/views rate = 11/227 dls/views = 0.048
not all that exciting
TinT
PostPosted: Mon Sep 26, 2016 11:38 am  (#17)
Going deep, Hilbert Curve Coloring, (be sure to click on the images).
At GC: Subject: Hilbert maze (mainly for Lylejk )
PostPosted: Mon Sep 26, 2016 3:54 pm  (#18)
Hilbert looks way above my level of thinking...
TinT
PostPosted: Mon Sep 26, 2016 4:33 pm  (#19)
Lindenmayer systems:
http://weitz.de/lindenmayer/
For Gimp L-system_v12.scm waiting for repair :gaah
