It is currently Mon Aug 24, 2026 11:26 pm
 Post subject: Label Arrows From Path (.py script) ...featuring Bruce Lee Parts
PostPosted: Sat Sep 24, 2016 12:57 pm  (#1)
This script spawned from this post --> mahvin's request for another Golden Wilbur
Release #1.
label_arrows_from_path.zip [5.85 KiB]
Downloaded 727 times
Menu location:
Options:
Instructions: ----------------------------------------------------------------------
Have an active path that defines your arrow(s).
Run Script -> result. (You'll get 3 layers, an arrows layer, a circle fill layer, and a numbers layer)
Note: This script is a stand-alone script. It has a copy of Ofnuts arrowheads code internally and does not depend on Ofnuts arrowheads .py script.
If ya find this script useful, you can thank Ofnuts, without his code I don't know how i'd hack the arrow heads (it's a little more complex and I think i would make it really messy) :hehe
TinT
 Post subject: Re: Label Arrows From Path (.py script) ...featuring Bruce Lee Parts
PostPosted: Sat Sep 24, 2016 3:10 pm  (#2)
Excellent! I actually tested it out on a small tutorial on my website. Good job, Tin!
PostPosted: Sat Sep 24, 2016 4:04 pm  (#3)
Does the direction of the arrows come from the order of the path nodes?
PostPosted: Sat Sep 24, 2016 4:26 pm  (#4)
Yep.
TinT
PostPosted: Sat Sep 24, 2016 4:26 pm  (#5)
I still want that Golden Wilbur! :hehe
TinT
PostPosted: Sat Sep 24, 2016 4:30 pm  (#6)
The Golden Wilbur, most coveted prize in the GIMP world. ;) I'll see that you get them.
PostPosted: Sat Sep 24, 2016 4:35 pm  (#7)
As I accept the the Golden Wilbur:
"I'd like to thank mahvin for coming up with the idea of this script. I'd like to thank fellow script coders like Ofnuts for his code. Without it this wouldn't happen. I'd like to thank Happy Smiling Big Belly Buddha! I'd like to thank The Lord, I'd like to thank my parents, ..." keeps on thanking people.
"And last but not least .. I'd like to thank Gimp Chat forum"
:hehe
TinT
PostPosted: Sat Sep 24, 2016 4:40 pm  (#8)
downloads/views rate = 9/99 = 0.09
9%
almost double the interest as the "Select guides surrounding path points script"
TinT
PostPosted: Sun Sep 25, 2016 4:15 am  (#9)
:hehe
Given the code, I want a 50% share on the prize :)
PostPosted: Sun Sep 25, 2016 5:19 am  (#10)
Interesting script.
A request or perhaps a challenge? Will you add the ability to use words within different shapes? :)
Also when i used a closed path it actually created a circle on the last node added and stroked the path but no arrow head. I just thought that was interesting to note. Makes for a different type of pointer at the end of the label.
Robs path label script in (Scheme) allows the user to add words at different node points. Just thinking if you used your words to shapes filter and add the path nodes to label arrows. What would that look like? :)
One more suggestion is to add all your current and future PATH filters to the <vectors> menu so a user could open them from the paths layers. It just seems like the proper place for them to be.
Thanks for the new script sir! :clap
PostPosted: Sun Sep 25, 2016 10:50 am  (#11)
I'll gladly share 50% of the prize. I think it's worth like a gazillion dollars.
TinT
PostPosted: Sun Sep 25, 2016 10:55 am  (#12)
Interesting script.
That's too hard of a challenge, I don't know how to fit words into different shapes.
As for menu change, if i put with vectors, it would see off since other ofnuts paths tools seem to generate other paths, this one doesn't generate paths. If you really want you can change that yourself.
I think the script is pretty good right now as is for labeling key points for tutorials.
TinT
PostPosted: Tue Oct 11, 2016 12:39 pm  (#13)
I just created my own "Golden Wilbur"
for my forum icon. hehe
TinT
PostPosted: Tue Oct 11, 2016 1:09 pm  (#14)
I like your "Golden Wilbur" icon. :bigthup
PostPosted: Tue Oct 11, 2016 1:35 pm  (#15)
yeah i added it as a smiley too just for kicks..
I wonder if anyone wants to volunteer (since i can't pay anything :oops: ) to design fun smilies for my forum?
here's one i did Image his eyes move
TinT
PostPosted: Tue Oct 11, 2016 9:18 pm  (#16)
I haven't forgotten your Golden Wilber! :)
PostPosted: Thu Apr 06, 2017 1:29 am  (#17)
cool and great. It's really useful
PostPosted: Thu Apr 06, 2017 3:04 am  (#18)
I'll try this.
PostPosted: Thu Apr 06, 2017 10:37 pm  (#19)
Could you give a thought to providing a text output as per image below
PostPosted: Fri Apr 07, 2017 6:17 am  (#20)
That is a great idea Graechan. I hope it can be added. Though i have not seen Tran around for a bit.
