It is currently Sat Aug 22, 2026 7:15 pm
 Post subject: new filter "RodStyleDetails"
PostPosted: Wed Oct 05, 2016 7:41 am  (#1)
Just released.
Another way to let details blow up in an image.
You may compare with previously release filter LyleStyleDetails.
Here some outcomes:
Rod Style Details on plumeria-209904_960_720-crop.jpg [ 489.21 KiB | Viewed 2702 times ]
Rod Style Details on summer_st_helens_by_sirgerg-dac5mdb.jpg [ 803.58 KiB | Viewed 2702 times ]
Rod Style Details on yosemite-1590012_960_720_crop.jpg [ 1.02 MiB | Viewed 2702 times ]
 Post subject: Re: new filter "RodStyleDetails"
PostPosted: Wed Oct 05, 2016 7:42 am  (#2)
Warning: if you like to use it on people images, better to select "Add noise"
(same if you use a source image with large black areas)
PostPosted: Wed Oct 05, 2016 7:47 am  (#3)
example on a people image (with noise added)
Rod Style Details on girl-1492616_960_720, noise added.jpg [ 1.2 MiB | Viewed 2696 times ]
PostPosted: Wed Oct 05, 2016 7:51 am  (#4)
example on an image with large black (very dark) areas
Rod Style Details on windows-lock-screen, noise added.jpg [ 975.05 KiB | Viewed 2695 times ]
PostPosted: Wed Oct 05, 2016 7:54 am  (#5)
Thank you Rod and Thank you Dinasset for this artistic filter to play with. :tyspin :coolthup
It produces very nice results too. :yes
PostPosted: Wed Oct 05, 2016 7:56 am  (#6)
yeah, particularly on landscapes, seascapes....
for my taste, at least
PostPosted: Wed Oct 05, 2016 8:03 am  (#7)
Beautiful images Dinasset. I played it on people with noise, too. :)
kittatinny-lake-1708835_1280-RodStyleDetails-DN.jpg [ 826.47 KiB | Viewed 2690 times ]
PostPosted: Wed Oct 05, 2016 8:20 am  (#8)
I had to experiment it on this nice filter. Here it is the same image with and without noise. I like both. :bigthup
PostPosted: Wed Oct 05, 2016 8:26 am  (#9)
good tests and nice outcomes, Issabella, thanks!
PostPosted: Wed Oct 05, 2016 8:44 am  (#10)
opened the related Gimp Art topic
we may post our tries there
here only for comments/requests on the filter itself
PostPosted: Wed Oct 05, 2016 9:49 am  (#11)
Do you plan on modifying it to run on GIMP 2.9.5 I get an error now:
NameError: global name 'INTERPOLATION_LANCZOS' is not defined
PostPosted: Wed Oct 05, 2016 9:54 am  (#12)
Sorry, I only use and work on stable releases of Gimp.
When the modifications introduced will be officially released (3.0?) I guess there will be a lot of filters in need of changes.
But if you get only that error I can try to find an escape way
Edit: if you can edit the filter, you may try replacing 'INTERPOLATION_LANCZOS' in line 90 with a simple '3'.
I ask you because I do not have that environment and I need to know whether this is the only difference
PostPosted: Wed Oct 05, 2016 10:13 am  (#13)
Thank you! That solved the problem and it works great now. Another fantastic plugin.
PostPosted: Wed Oct 05, 2016 10:16 am  (#14)
Very good, bilbo, so now it can be used also on 2.9.5 with that modification, thanks
PostPosted: Wed Oct 05, 2016 10:27 am  (#15)
Also, by making the same modification on the Lyle_Style on line 116 and adding the diego_stretch_rgb_colours.py plugin, got that working also.
PostPosted: Wed Oct 05, 2016 10:31 am  (#16)
thanks!
PostPosted: Fri Oct 07, 2016 3:42 am  (#17)
Hello,
thanks for this script. Here great results are possible.
Example: My Chancellor, a beauty contest would certainly not win.
Regards Hardy111
PostPosted: Fri Oct 07, 2016 6:56 am  (#18)
thanks for trying (less for the subject, she is already ubiquitous, on newspapers, TV, ...hehehe)
