It is currently Sun Nov 22, 2026 4:28 pm
 Post subject: Fill Selection with Perspective Brush Script for GIMP.
PostPosted: Tue Nov 01, 2016 3:04 am  (#1)
Originated from lylejk and described by rich2005
download script here --> Fill Selection With Perspective Brush Script for GIMP.
Last edited by trandoductin on Wed Nov 28, 2018 12:21 pm, edited 2 times in total.
 Post subject: Re: Fill Selection with Perspective Brush Script for GIMP.
PostPosted: Tue Nov 01, 2016 7:54 am  (#2)
just a play
if Lyle "accepts" your way, there is room for interesting enhancements, Tin:
- select all if none
- defining initial brush size
- defining x starting point
Lyle, how do you see it?
PostPosted: Tue Nov 01, 2016 8:41 am  (#3)
It's still a cool script, regardless. Haha! Thanks, Tin!
PostPosted: Tue Nov 01, 2016 8:47 am  (#4)
Thanx for sharing.
PostPosted: Tue Nov 01, 2016 2:44 pm  (#5)
just a play
- select all if none, i could add.
- defining initial brush size, it uses whatever the active brush size is set to, and by specifying horizon percentage you're controlling how narrow your far away brushes should look, then i use this percentage to decide brush size for brushes near horizon starting y. I don't see the point to defining intial brush size.
- defining x starting point? what's that? right now it's just based on your selection x1. what other x can there be if you specify x starting point?
PostPosted: Tue Nov 01, 2016 11:36 pm  (#6)
Tin, I was too concise, so it's not clear what I mean:
- initial brush size: the filter takes the "defined" brush size of the active brush, it could be useful let the filter have a parameter which allows to change it before taking that value as initial value, without defining another brush size
- by x starting point I mean the possibility to create a perspective which has a specific "punto di fuga" ( I don't know how to translate it); if you see my play the "punto di fuga" is at centre and not at x0 as created by default by the filter, I had to duplicate the layer, reverse it and merge to get it.
That's all.
edit: likely the term in English is "vanishing point"
PostPosted: Tue Nov 01, 2016 11:55 pm  (#7)
example of a field with flowers having a vanishing point not at x0
PostPosted: Wed Nov 02, 2016 12:03 am  (#8)
The vanishing point is only used if you have a roadway or a hallway or something that leads to a point.
Because this is perspective based on any selected area. the vanish points are along all the x's
as an example here you can see (I used 1 as percentage for horizon) it looks like everything is vanishing to the horizon.
EDIT: I think i know what you mean, you want the user to be able to control the loop's x where things start out aligned. I'll update soon another version soon.
PostPosted: Wed Nov 02, 2016 1:13 am  (#9)
Version 2 is up.
Select All if none is selected.
Added option to specify Vanishing X at percentage (of selection) (default at 50 percent, center of selection).
PostPosted: Wed Nov 02, 2016 1:15 am  (#10)
thanks a lot Tin
PostPosted: Wed Nov 02, 2016 1:17 am  (#11)
Thank you for suggesting improvements.
another play with version 2 (with peppers.
PostPosted: Wed Nov 02, 2016 2:36 am  (#12)
version 3 is up.
Allow "RANDOM" placement in addition to "ALIGNED" placement.
PostPosted: Wed Nov 02, 2016 4:37 am  (#13)
Wow, maybe you are ready to add also a "random" angle (with moderate variations....) to get trees leaning slightly to the right and to the left....
PostPosted: Wed Nov 02, 2016 5:56 am  (#14)
Freaking awesome, Tran. Have to leave for work, soon, but I will be playing with your genius of a result soon. Thanks a heap. :)
PostPosted: Wed Nov 02, 2016 7:35 am  (#15)
Nice additions to the brush Tran. I would really like to be able to control it with a path though. ;) ;)
Say like every node place a brush the more -Y the smaller the brush
Settings
This took 7 minutes to render :lol (1000x1000 pixels)
Very cool results though. :bigthup
By the way the brush itself has transparency that is not your filter doing that.
PostPosted: Wed Nov 02, 2016 12:02 pm  (#16)
path coming up soon, now i gotta look around and see what i can do.
:hehe
PostPosted: Wed Nov 02, 2016 12:16 pm  (#17)
:hehe
:tyspin :wh
PostPosted: Wed Nov 02, 2016 1:36 pm  (#18)
It's up, give it a run and let me know if that's what you want.
http://gimpchat.com/viewtopic.php?f=9&t=14849&p=206023#p206023
PostPosted: Wed Nov 02, 2016 6:02 pm  (#19)
Pepperoni in perspective. lol
Again, thanks a heap, Tran. :)
PostPosted: Wed Nov 02, 2016 9:04 pm  (#20)
Alphabet's perspective
Used liquid rescale to squeeze the characters even closer together. Not sure how to pack brush output better, but LqR does a reasonable job doing this. :)
