It is currently Sun Nov 22, 2026 5:29 pm
 Post subject: Follow Path With Perspective Brush for GIMP
PostPosted: Wed Nov 02, 2016 1:34 pm  (#1)
Requested by Rod,
To base the brush size on Y-coordinate (to create fake 3D perspective effect).
Click here for download --> Follow Path with Perspective Brush for GIMP
 Post subject: Re: Follow Path With Perspective Brush for GIMP
PostPosted: Wed Nov 02, 2016 2:02 pm  (#2)
version 2 is up.
Fixed a Track Direction (angle) bug.
PostPosted: Wed Nov 02, 2016 3:41 pm  (#3)
version 3 is up.
Added forgotten progress bar updates for friendliness.
and here's a sample run of paths where i drew rows of trees.
PostPosted: Wed Nov 02, 2016 4:22 pm  (#4)
Version 4 is up.
Draws smaller brushes first because smaller brushes in the foreground would look weird in front of nearer (larger) brushes.
Version 5 is up. Forgot stupid progress bar update again.
PostPosted: Wed Nov 02, 2016 10:51 pm  (#5)
Hi
I am sorry to say that after using different settings I am unable to get change in size in terms of perspective. Perhaps I am unable to find suitable combination of settings. I get straight line of repititive objects without diminishing size.
Bye
PostPosted: Wed Nov 02, 2016 10:54 pm  (#6)
are you drawing a line from top to bottom? size changes based on y-coordinate.
If you draw a straight horizontal line there would be no changes in size.
PostPosted: Thu Nov 03, 2016 12:25 am  (#7)
I have tried two versions but I get the same result. First tried 5th and then removed and installed 3rd version. I am attaching screenshots of the process.
PostPosted: Thu Nov 03, 2016 12:40 am  (#8)
what is your brush?
it looks small on image 2 but how does it even fill the whole image in 3 it looks like.
It should only brush along the path.
PostPosted: Thu Nov 03, 2016 1:21 am  (#9)
I have changed the brush but no perspective change.
PostPosted: Thu Nov 03, 2016 1:32 am  (#10)
I don't know what's the problem could be.
You're using GIMP 2.8 right?
I remember long time ago I wrote a script in scheme (I think it was the Green Apple Script), where i tried setting the context's brush attributes such as size and it didn't seem to do anything, i had to create a new brush myself in order for script to work.
But i am using 2.8 now and setting the context's set brush size works fine now.
So i am wondering if you might be using an older GIMP.
Other than that possibility I don't know why is isn't working for you.
PostPosted: Thu Nov 03, 2016 6:00 am  (#11)
Thank you Tran. I made a gear following a gear path. :) Nice filter.
PostPosted: Thu Nov 03, 2016 6:10 am  (#12)
And one with smaller brush settings. The last one was 30 min and 40 max
This one has the settings below.
Very Cool! :bigthup
PostPosted: Thu Nov 03, 2016 6:47 am  (#13)
Again, I want it in my simple shape plugin...
Follow_Path_With_Perspective_Brush in Gimp 2.9.5.png [ 338.59 KiB | Viewed 3128 times ]
PostPosted: Thu Nov 03, 2016 7:37 am  (#14)
That is a great example of this filters potential MareroQ! :clap
PostPosted: Thu Nov 03, 2016 8:35 am  (#15)
Does it look-like your tree-plantaion image?
Created a new Brush Dynamic with Size Variation(Size-->Pressure & Fade checked).
PostPosted: Thu Nov 03, 2016 9:07 am  (#16)
yes it does look like it, nice work.
But are you using GIMP 2.8 or older GIMP?
EDIT: for a second there i thought the script worked for you, but after looking at it carefully i notice the size variation only seem to happen at the top, it doesn't gradually happen throughout the whole y-coordinate space like the fake 3D effect.
PostPosted: Thu Nov 03, 2016 9:59 am  (#17)
I am using Gimp 2.8.10. The point of concern is the result of the result of the script which is against expectation.
PostPosted: Thu Nov 03, 2016 10:03 am  (#18)
I am using 2.8.16.
It's a concern but if it's an older bug in 2.8.10, I don't want to have create my own brush when the active brush is supposed to work fine.
Found something related to this: https://www.bountysource.com/issues/137 ... ont-t-work.
PostPosted: Thu Nov 03, 2016 10:17 am  (#19)
My discipline has been 'Plant Sciences (Botany)'. Computer programs are horrible things to me. I visited the site but couldn't understand the importance of the code for console. Apologies.
PostPosted: Thu Nov 03, 2016 10:31 am  (#20)
You can actually do that with "WHEEL" and "FADE" in the brush dynamics editor (if you have the wheel in your mouse set to size increase or decrease), . BUT it will only make a small brush and then the rest larger but the same size. Your script is a whole lot different Tran.
