It is currently Sun Nov 22, 2026 3:31 pm
 Post subject: Extrude Active Layer with Active Path script for GIMP
PostPosted: Fri Nov 04, 2016 1:15 pm  (#1)
There are variety of scripts that extrude.
But I thought i make one that allows you define a path to extrude and it uses the active gradient as you extrude.
and you can specify start brush size percentage.
In the sample below I bump-mapped my white text first before using script. I left the bump mapping out so users can be creative before applying script.
click here to download --> Extrude Active Layer with Active Path Script for GIMP
 Post subject: Re: Extrude Active Layer with Active Path script for GIMP
PostPosted: Sat Nov 05, 2016 2:54 am  (#2)
75% brush and simple bump map on a bluish text. Time to render 32 seconds
PostPosted: Sat Nov 05, 2016 4:50 am  (#3)
Corel Draw has such effects. Excellent.
PostPosted: Thu Nov 10, 2016 10:53 am  (#4)
For MR. RJKD
xcf file of result of a trial for the above script. File has got only three layers.
Result was very dark and I was also disappointed but then I changed the Value curve to the lighter side and things started to become clear.
Gradient used was perhaps 'Incandescent'.
I wish it could be useful to you in some way.
Super Moon.xcf [105.67 KiB]
Downloaded 192 times
PostPosted: Fri Jun 20, 2025 9:25 am  (#5)
Any one that has this plugin please attach it here.
Thank you! :)
PostPosted: Fri Jun 20, 2025 9:43 am  (#6)
Extrude_With_Path_4.7z [2.5 KiB]
Downloaded 61 times
Thank you Rich! :)
