It is currently Fri Aug 21, 2026 8:06 pm
 Post subject: Pat625 Mandala With Your Name Script for GIMP
PostPosted: Tue Nov 22, 2016 10:34 pm  (#1)
Pat625 just wrote a fun mandala tutorial.
Make you sure you go through the tutorial to know how it is created and download the needed beautiful fonts used for the Mandala. Once you've done that then you're good to play with this script otherwise you'll have to use default boring fonts.
More details and download script, click here --> Pat625 Mandala With Your Name Script for GIMP
TinT
 Post subject: Re: Pat625 Mandala With Your Name Script for GIMP
PostPosted: Fri Nov 25, 2016 8:32 am  (#2)
Thank you so much Tin. it works great! :) :tyspin
PostPosted: Fri Nov 25, 2016 9:01 am  (#3)
Thanks again for your tutorial, Pat, but really, because I'm a lazy bas(expletive)rd, I thank you too, Tran for automating the process. Did add a bit of fun to the result as well. :)
PostPosted: Fri Nov 25, 2016 10:44 am  (#4)
Great ides Pat and thanx for the script T
PostPosted: Fri Nov 25, 2016 8:36 pm  (#5)
Image Great script.
