It is currently Sun Aug 23, 2026 8:29 pm
 Post subject: My minimal Gtk plugin (a template?!) using Dialog
PostPosted: Wed Feb 01, 2017 11:56 am  (#1)
Struggeling with nice UI I learned a lot from guidelab.py (rather nice!), which meanwhile has grown to my guidelab_paint.py ... where the latest version can put checker pieces on a checkboard, two lines in a file first for black stones, second the white stones.
Now busy to make use of it in Gimp as a checker-beginner.
The plugin for that is already on the way (see other thread of me ;) )
That UI is a very minimal Dialog-window!
Scrapped the checker code (mostly) it became this:
gtkMINI_1feb.zip [2.33 KiB]
Downloaded 136 times
Please have a look and Comments are very welcome!
After extracting into a plugin-directory where Gimp looks the plugin
shows as GTK ==>MINIdialog
Greets
Peter
 Post subject: Re: My minimal Gtk plugin (a template?!) using Dialog
PostPosted: Wed Feb 01, 2017 2:54 pm  (#2)
gtkMINI_1feb.zip
Greets
Peter
Thanks Peter! :bigthup
It will be interesting to see where it goes from here. :)
PostPosted: Thu Feb 02, 2017 2:39 am  (#3)
Mini example,
Used like this
Stone 42 was mentioned, a black stone, promoted ;-)
At this moment no more options needed.
The UI stays on the window (made stay on top!), difference to 'normal' plugin-UI's.
Peter
