It is currently Mon Aug 24, 2026 7:24 am
 Post subject: Parallax animation script for GIMP
PostPosted: Wed Feb 08, 2017 4:43 pm  (#1)
Online
After the scrolling script....of course a Parallax animation script has to be done.
Sorry I am not so great at drawing....but you see mountains moving slowest at lowest layer...then clouds, then trees move the fastest...creates a parallax illusion
More details and instructions here --> Parallax animation script for GIMP
TinT
 Post subject: Re: Parallax animation script for GIMP
PostPosted: Wed Feb 08, 2017 5:22 pm  (#2)
Technically, the clouds should be after the mountains. As they are they look more like smoke.
Cool script, otherwise.
PostPosted: Wed Feb 08, 2017 5:35 pm  (#3)
Online
you're right. I wasn't thinking right...
clouds should be further than mountains.. i guess they're fog or smoke then hehe.
"Cool script" coming from you means a lot to me. Thanks.
TinT
PostPosted: Thu Feb 09, 2017 12:15 am  (#4)
Good.
PostPosted: Thu Feb 09, 2017 6:14 am  (#5)
I haven't looked at the code yet :)
PostPosted: Thu Feb 09, 2017 4:22 pm  (#6)
Online
don't look at the code....
I like it to stay a "Cool script".
TinT
PostPosted: Thu Feb 09, 2017 6:55 pm  (#7)
Well, looked at the code. Not bad, but I would do it differently:
  • Duplicate the layers horizontally (number of duplicates=relative speed, so you have N+1 copies total), while keeping the canvas the same.
  • Then your loop:
    • shifts layers by 1,2,4 pixels... (you can just update their offsets directly IIRC)
    • does a new-from-visible (frame = pdb.gimp_layer_new_from_visible(source_image, animation_image, name))
    • adds that frame layer to animation_image
Likely faster and simpler since you have two images.
And your loop for each frame can contain a loop over the N layers (this avoids some more code repetition), making it easy to make a script that supports more than 3 layers if necessary. For instance you can have the shift coded in the layer name, or required N layers (N=8 or so), shifted 1px, 2px, 3px... and for the the speeds that are not used the user just adds a transparent layer.
Script still cool, but can become cool, efficient and elegant :)
PostPosted: Thu Feb 09, 2017 7:11 pm  (#8)
Online
I said don't look at the code heheheh.
maybe you can do the elegant version and post it on http://www.gimp-forum.net
Edit: Thanks ofnuts, with your suggestions. I used some.
Such as creating layers with N+1 duplicates. and translating layer then get layer from visible and it's way faster and what's nice is you get to see the animation run in layers window as it's generating. I don't think i'll add the ability to create dynamic number of layers because I think next layer is 8x speed is too fast.
I am happy with it right now (version 3).
TinT
PostPosted: Fri Feb 10, 2017 10:14 pm  (#9)
Thanks Tin, I really like this script!
PostPosted: Mon Jun 05, 2017 4:37 pm  (#10)
Hi, need help w/ the Parallax plug-in..
I've used it before and it seemed fine, now I'm trying to do a short animation using it and can't seem to get it to work..
I'm using the version (3) and have 4 layers - one background to remain stationary and 3 layers above it (paintbrush on alpha channel x 3)
and when I run the plug-in I get the following message:
"Traceback (most recent call last):
File "C:\Program Files\GIMP 2\32\lib\gimp\2.0\python\gimpfu.py", line 736, in response
File "C:\Program Files\GIMP 2\32\lib\gimp\2.0\python\gimpfu.py", line 361, in run_script
File "C:\Users\marti\.gimp-2.8\plug-ins\parallax.py", line 113, in python_parallax
pdb.gimp_layer_translate(new_bg,scrollx,0)
RuntimeError: Procedure 'gimp-layer-translate' has been called with an invalid ID for argument 'layer'. Most likely a plug-in is trying to work on a layer that doesn't exist any longer."
So, could someone help me out with this, as stated it used to work fine when I first used it (was on 2.8.20 then - on 2.8.22 currently..)
Thanks,
Martin
EDIT: I now just got it to work, but strangely I first had to change the order of layers by putting the bottom layer up to second place, then run the script, it did what it was supposed to do (but in the wrong order) then I deleted that and went back to the original (where it had created copies of the 4 layers) deleted the copies then re-ordered so it was back to how i wanted it, then ran it again and it worked fine!! Hopefully this is a work round to the problem, not sure if it'll happen again or why it's happening in first place... anyway - it's a FANTASTIC script (when it works ;))
PostPosted: Mon Jun 05, 2017 5:06 pm  (#11)
Online
I can't reproduce this error.
I am running 2.8.22
and version (3).
TinT
PostPosted: Mon Jun 05, 2017 5:14 pm  (#12)
I am running 2.8.22
and version (3).
OK, no problem, thanks for trying.. well it seems to be something to do with my set-up perhaps, but I got it to work now luckily so it's all good - and thanks for all your great scripts! I must admit I have quite a few from you now, in fact I used your cross stitch script in a way it was probably not intended lol ... check it out around 1:17..
Cheers!
PostPosted: Mon Jun 05, 2017 5:34 pm  (#13)
This was done using one version of the parallax script..
PostPosted: Mon Jun 05, 2017 6:30 pm  (#14)
Online
trippy video.
cool parallax
TinT
PostPosted: Tue Jun 06, 2017 3:49 am  (#15)
It works here too. It could use additional options like direction etc.
