It is currently Mon Nov 23, 2026 2:06 pm
 Post subject: Nelo Plaid Background Script for GIMP
PostPosted: Wed Feb 15, 2017 2:21 am  (#1)
Nelo has a cool trick creating backgrounds like this
Here's the script that does it for you save you a few manual steps -> Nelo Plaid Background Script for GIMP
 Post subject: Re: Nelo Plaid Background Script for GIMP
PostPosted: Wed Feb 15, 2017 3:09 pm  (#2)
Is it different to the one in GMIC where you can turn a picture into plaid?
PostPosted: Wed Feb 15, 2017 3:12 pm  (#3)
I didn't know G'MIC had one, but if I don't have to leave GIMP to do something I'm happy!!
PostPosted: Wed Feb 15, 2017 3:33 pm  (#4)
It's under patterns
Just open picture of the colors you would like as a plaid and it will do it according to the amount of colours in it.
EDIT: Actually this is just default setting you can change them to your liking
PostPosted: Wed Feb 15, 2017 4:22 pm  (#5)
I didn't know GMIC had that one either.
But the results looks different.
PostPosted: Wed Feb 15, 2017 9:31 pm  (#6)
Did this one with Tran's Nelo Plaid Script.
PostPosted: Thu Feb 16, 2017 3:56 am  (#7)
My first one using this script
PostPosted: Thu Feb 16, 2017 1:03 pm  (#8)
Here's one using my Gimp Chat avatar.
PostPosted: Thu Feb 16, 2017 2:32 pm  (#9)
Hallo, the Scrip found by me found no clipboard that give error "»gimp-context-set-pattern«". I not sure witch step let I let out.
I native not English and my English not always the best.
PostPosted: Thu Feb 16, 2017 5:13 pm  (#10)
In other languages the word "clipboard" does not exist, to set the clipboard pattern for all languages as the active pattern in scheme I used
(gimp-context-set-pattern (caadr (gimp-patterns-list "")))
PostPosted: Sat Feb 18, 2017 4:32 am  (#11)
nice one:) Wallace
PostPosted: Sat Feb 18, 2017 1:22 pm  (#12)
Graechan wrote:
abraess wrote:
Hallo, the Scrip found by me found no clipboard hathat give error "»gimp-context-set-pattern«". I not sure witch step let I let out.
Hallo thank you. But I'm a User not programmer, so not sure where I have put this line. Plugin and skipt fu to programming is for to high.
PostPosted: Sat Feb 18, 2017 1:32 pm  (#13)
I pm you.
Please try version 2 of script. It should solve the "Clipboard" hardcoded problem.
PostPosted: Sat Feb 18, 2017 6:20 pm  (#14)
Hello trandoductin,
thank you, that script do it. For me was difficult because not know what I had make false. The Gmic Version worked and after some tries, I could even do it by hand. I do this possible once before but forgot it. Now is easyer for me.
PostPosted: Mon Mar 24, 2025 5:22 pm  (#15)
At the request of the baboca :)
viewtopic.php?f=9&t=21593
Nelo Plaid Background Ver.2 by Tin Tran
nelo_plaid_background_2.zip [1.45 KiB]
Downloaded 62 times
