It is currently Sun Aug 23, 2026 7:48 am
 Post subject: Nufraw-0.39 for GIMP-2.9 Win
PostPosted: Sat Feb 18, 2017 3:30 pm  (#1)
The latest build of GIMP 2.9.5 (Win 64bit) by Partha (https://www.partha.com/) is a new compilation nufraw by Matteo Lucarelli (https://sourceforge.net/projects/nufraw/files/?source=navbar).
Nufraw operates as a standalone program - but also as a plug-ins GIMP.
Available language versions (translations):
ca,cs,da,de,es,fr,it,ja,ko,nb,nl,pl,pt,ru,sr,sr@latin,sv,zh_CN,zh_TW.
I compiled this for GIMP 2.9 and Win32bit - it works well as a standalone program and the plug GIMP.
The only problem when:
- Run nufraw,
- Open the raw file in nufraw,
- Process and save,
- Send to GIMP - gimp starts but with an error message (not open the image).
Question:
If it works (Send to GIMP) for version Partha ?
 Post subject: Re: Nufraw-0.39 for GIMP-2.9 Win
PostPosted: Sat Feb 18, 2017 3:52 pm  (#2)
There is a coincidence. Just compiled nufraw 0.39 for my Kubuntu Gimp 2.95 Some people knock the old ufraw but I like this rehashed version.
One peculiarity. When the plug-in is enabled (made executable in linux) Gimp 2.9.5 will not open a SVG file. Some conflict somewhere but not a major problem.
PostPosted: Sat Feb 18, 2017 4:28 pm  (#3)
Thank You for the quick test.
UFRaw version 0.19.2 also works for Gimp 2.9.5 for Windows (but you have to choose : UFRaw or Nufraw - different requirements for the library liblensfun.dll)
For the version of GIMP 2.9.5 (Dark Refraction gimp-dev-i686-2017-02-18.exe http://nightly.darkrefraction.com/gimp/dev/) or build your own - problem with svg file is does not exist.
ps. For Vista 32bit Gimp in Dark Refraction requires changes in several files.
PostPosted: Sun Feb 19, 2017 12:58 pm  (#4)
For those willing to test - my version of 32bit GIMP 2.9
https://www.dropbox.com/sh/4jdljl4gprzh091/AADQ5fMYVykiqI8NkSZBQNl4a?dl=0&preview=Nufraw-0.39_32bit.zip
PostPosted: Mon Feb 20, 2017 5:30 am  (#5)
MareroQ wrote:
...snip...
- Run nufraw,
- Process and save,
Question:
Is this the problem: https://sourceforge.net/projects/gimp-w ... in-remote/
gimp-win-remote.exe is old (2006)
