It is currently Mon Aug 24, 2026 5:42 pm
 Post subject: New version 1.04 of joined up text plugin
PostPosted: Mon Feb 20, 2017 6:22 am  (#1)
Here is a new version of the Joined-upText plugin - version 1.04 - intended to work on Gimp version 2.8. If the old script worked on earlier versions of Gimp this should work too.
This script requires the installation of my JoinerVariations-v4 and ItalicVariations True Type fonts. It is not compatible with earlier versions of JoinerVariations so it is best to remove older versions of the script as well the JoinerVariations-v3 font to avoid problems. JoinerVariations-v4 will appear as JoinerVariations in your font lists.
Download the zipped folder with the necessary files here:
JoinedUpVersion4.zip [52.25 KiB]
Downloaded 227 times
The filter now accesses two joined-up fonts from the filter menu. The image below illustrates the two fonts with their font character variations:
The filter menu dialog has been updated to reflect these changes but, as a consequence, it is rather less specific in the letter variations.
The filter can be accessed via Filters > Text FX > Joined-up Fonts... dialog. Here is the usual link to a topic about viewing large dialog boxes in py scripts.
viewtopic.php?f=9&t=13714
 Post subject: Re: New version 1.04 of joined up text plugin
PostPosted: Mon Feb 20, 2017 6:25 am  (#2)
And an example of the plugin when applied to a circle path as part of an image:
PostPosted: Mon Feb 20, 2017 12:05 pm  (#3)
Looks really very nice!
PostPosted: Mon Feb 20, 2017 2:03 pm  (#4)
Thank you Pat - hope you will join the fun!
