It is currently Tue Aug 25, 2026 11:14 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: Custom Font on Path Script for GIMP.
PostPosted: Thu Feb 23, 2017 1:04 am  (#1)
This script works with other Custom Fonts.
Just a warning it'll only look for ' .png' (that's a space then .png), not 'space.png'.... so if you have .xcf files that have space.png please rename them to ' .png'
more details here -> https://gimplearn.net/viewtopic.php?t=449
TinT
 Post subject: Re: Custom Font on Path Script for GIMP.
PostPosted: Thu Feb 23, 2017 2:16 am  (#2)
Thanks tran
Downloaded. Will try later today.
PostPosted: Thu Feb 23, 2017 2:27 am  (#3)
Thanks for trying.
TinT
PostPosted: Thu Feb 23, 2017 5:32 am  (#4)
Script did not change lower case to upper case when no lower case was in file e.t.c., it still needs some goodies added
PostPosted: Thu Feb 23, 2017 6:58 am  (#5)
Totally surprised you didn't just add this to the current custom_font.scm script but hey this is a great idea Tran! :)
I concur with Graechan on the caps though. I had to use all small case letters. Symbols work okay though. :bigthup
PostPosted: Thu Feb 23, 2017 7:23 am  (#6)
:coolthup :tyspin
PostPosted: Thu Feb 23, 2017 9:05 am  (#7)
Really useful. Well done.
Text box is visible only as a thin line. I entered text by guess.
PostPosted: Thu Feb 23, 2017 10:48 am  (#8)
Graechan, thanks for mentioning about the upper/lower case
I added in release 2 and while i was at it added to look for 'space.png' or ' .png' as well so previously created .xcf font files don't have to be edited.
PS. thanks for trying version 1 out people. it's nice to see many results.
TinT
PostPosted: Thu Feb 23, 2017 10:55 am  (#9)
I didn't want to change the dirty looking .scm file, it would be more work trying to add to or change the .scm ... Starting a new .py file would be less effort.
It wasn't my idea to create this script. It was Pat625 who requested it.
TinT
PostPosted: Thu Feb 23, 2017 11:06 am  (#10)
PostPosted: Thu Feb 23, 2017 12:23 pm  (#11)
Blighty II wrote:
hehehe
TinT
PostPosted: Thu Feb 23, 2017 12:52 pm  (#12)
Thanks for the update Tran and thank you Pat for the idea! :)
PostPosted: Thu Feb 23, 2017 1:00 pm  (#13)
Just had to play with it!!! What's better than new toys after Christmas????
PostPosted: Thu Feb 23, 2017 1:03 pm  (#14)
Blighty, That's good! I could read it quite well!!
PostPosted: Thu Feb 23, 2017 1:04 pm  (#15)
:hehe your a good man
PostPosted: Thu Feb 23, 2017 3:06 pm  (#16)
Don't forget to thank ofnuts for his angle calculation from 2 points and slope formula.
I stole that piece of code for this script to rotate the characters to be perpendicular to path. hehe
TinT
 Post subject: Re: Font on Path Script for GIMP.
PostPosted: Thu Feb 23, 2017 6:35 pm  (#17)
Thank you very much, Ofnuts for your angle calculation code for Tran's Script!!
PostPosted: Thu Feb 23, 2017 9:05 pm  (#18)
Rel2, a definite Improvement, and as for the copied code ofnuts would agree that there's no use reinventing the wheel :hehe
PostPosted: Fri Feb 24, 2017 9:16 am  (#19)
Thank you Ofnuts! :)
PostPosted: Fri Feb 24, 2017 9:52 am  (#20)
Thank you so much Ofnuts and Tin really all of you when working as a real effective wonderful team. :jumpclap
