It is currently Mon Aug 24, 2026 6:49 pm
 Post subject: Script/Plugin Request
PostPosted: Sun Feb 26, 2017 7:17 pm  (#1)
I've had problems with "pencil portrait" on G'MIC. Works, but takes forever. Is it possible to make a stand alone script/plugin for this feature? I wondered if it would take as long if separate? Thanks.
 Post subject: Re: Script/Plugin Request
PostPosted: Sun Feb 26, 2017 10:01 pm  (#2)
Have you tried Rod's or Dinasset's Pencil Portrait scripts?
PostPosted: Mon Feb 27, 2017 12:21 am  (#3)
Huh uh. I was wanting the same Pencil Portrait as on G'MIC. Love that feature.
PostPosted: Mon Feb 27, 2017 1:50 am  (#4)
I don't think G'MIC is slow because it has many filters, since when you select a filter it goes into that piece of code it's not running other things at the same time.
I wouldn't know how to reproduce the effect in G'MIC in GIMP.
Unless you knew the steps to reproduce it in GIMP then i could script it but i doubt it'll be faster, probably even slower (as i think G'MIC is already compiled code).
TinT
PostPosted: Mon Feb 27, 2017 6:23 am  (#5)
I wondered if it wouldn't be slower. Funny that it's the only feature on G'MIC that does that.Everything else works fine. I uninstalled it, and reinstalled it, to no avail. It used to work fine, then all of a sudden didn't anymore. I don't know if it was from something different in G'MIC itself, or something wrong with my PC.
It seems others have the same problem with it: viewtopic.php?f=28&t=13648
PostPosted: Mon Feb 27, 2017 11:55 am  (#6)
Try to follow the original tut
http://gimpchat.com/viewtopic.php?f=23&t=5948
PostPosted: Mon Feb 27, 2017 2:37 pm  (#7)
I created script that does what this tutorial described.
It's slow on large images, so i only tested with image of 400pixel width.
more details -> Jamac4k Pencil Portrait Script For GIMP
by the way it was really easy too that you posted the gmic command used for the plugin...but how did you get that command string? is there an output of that somewhere when you run any gmic filter?
TinT
PostPosted: Mon Feb 27, 2017 3:06 pm  (#8)
@ Tin
"...but how did you get that command string? is there an output of that somewhere when you run any gmic filter?"
third entry in Input/output, use "Verbose (layer name)", you'll get the command string used
PostPosted: Mon Feb 27, 2017 4:10 pm  (#9)
Thanks jamac4k.
Thanks tin, but after 5 minutes, I gave up.
PostPosted: Mon Feb 27, 2017 5:47 pm  (#10)
Problem is Ink Wash usually is so slow.
I just doing the tut changing Ink Wash by Freaky B&W (default values):
File comment: Freaky B&W instead of Ink Wash
File comment: Tran script, 1920 x 1920
PostPosted: Mon Feb 27, 2017 6:10 pm  (#11)
Very nice jamac4k. Thanks again, appreciate it. Perhaps tin can alter the plugin.
PostPosted: Mon Feb 27, 2017 9:59 pm  (#12)
It's not Inkwash it's slow but it is not that slow.
It's the Sketch layer that takes the longest for me.
TinT
PostPosted: Tue Feb 28, 2017 5:57 am  (#13)
It seems odd to me. Sketch by itself doesn't take much time at all.
