It is currently Sun Aug 23, 2026 7:48 am
 Post subject: LIMN path rotator 2 update request
PostPosted: Tue Mar 14, 2017 12:02 pm  (#1)
Could some script guru please update this old script to work with 2.8?
It's called path rotator 2, menu name is duplicate and rotate a path
Made by "Lightning is my name" back in 2008 for 2.4, running in 2.8 spits multiple errors on my face
I know there are many great rotation tools, multi replicate, clone layer tool, Rotate nLayer, Ambigram rotation etc.
but they are layer rotators and some have limited amount of copies. This is for paths and has option to create up to 360 copies.
Unless there is something that outdoes it already of course.
Found it from this gimptalk thread
http://www.gimptalk.com/index.php?showtopic=29615
 Post subject: Re: LIMN path rotator 2 update request
PostPosted: Tue Mar 14, 2017 12:26 pm  (#2)
Try this one, remember to un-zip it
PathRotator2.scm.zip [1.31 KiB]
Downloaded 216 times
PostPosted: Wed Mar 15, 2017 9:59 am  (#3)
Woohoo! Thank You very much rich2005, works perfectly now :bigthup
