It is currently Sun Aug 23, 2026 4:28 pm
 Post subject: Same operation on all open images
PostPosted: Tue Mar 21, 2017 12:50 am  (#1)
Hi,
I'm attempting my first script, I've gone through a tutorial, successfully edited and ran a simple script on a single image.
Now I want to write a script which when run will operate on all open images. Is there a function which returns an array of all image objects? I did find a function that returns all image_ids, and that is pdb.gimp_image_list(). But I need the object it seems, as an input to the function I am wanting to perform.
The code:
for tempimage in pdb.gimp_image_list():
pdb.plug_in_unsharp_mask(tempimage, drawable, radius, amount, threshold)
pdb.gimp_desaturate_full(tempimage.active_drawable, desaturate_mode)
Returns an error that the wrong type is being used in the unsharp mask function, tempimage. I need the object and not the id. Any suggestions?
Thanks
David J.
 Post subject: Re: Same operation on all open images
PostPosted: Tue Mar 21, 2017 1:33 am  (#2)
as Tin said under Gimp-Learn:
You could try
gimp.image_list()
it'll return all images as objects currently opened that you can use.
PostPosted: Tue Mar 21, 2017 4:00 am  (#3)
I concur with dinasset, gimp.image_list() returns a list of gimp.Image objects.
Maybe show us a bit more code. The "wrong type" message could be for another parameter. What are the contents of the other variables (drawable, radius, amount, threshold).
PostPosted: Tue Mar 21, 2017 2:12 pm  (#4)
gimp.imagelist() is exactly what I'm trying to use in the snippet above. I'm editing the plugin from a working exercise plugin, which operates on one image and works.
The working code that works on one image:
#!/usr/bin/env python
from gimpfu import *
def extreme_unsharp_desaturation(image, drawable, radius, amount, desaturate_mode):
    # Unsharp mask from filters menu
    pdb.gimp_image_undo_group_start(image)
    threshold = 0
    pdb.plug_in_unsharp_mask(image, drawable, radius, amount, threshold)
    pdb.gimp_desaturate_full(drawable, desaturate_mode)
    pdb.gimp_image_undo_group_end(image)
register(
    "python-fu-extreme-unsharp-desaturation",
    "Unsharp mask and desaturate image",
    "Run an unsharp mask with amount set to 5, then desaturate image",
    "Jackson Bates", "Jackson Bates", "2015",
    "Extreme unsharp and desaturate...",
    "RGB", # type of image it works on (*, RGB, RGB*, RGBA, GRAY etc...)
        # basic parameters are: (UI_ELEMENT, "variable", "label", Default)
        (PF_IMAGE, "image", "takes current image", None),
        (PF_DRAWABLE, "drawable", "Input layer", None),
      (PF_SLIDER, "radius", "Radius", 5, (0, 500, 0.5)),
      (PF_SLIDER, "amount", "Amount", 5.0, (0,10,0.1)),
      (PF_RADIO, "desaturate_mode", "Set Desaturation Mode: ", DESATURATE_LIGHTNESS,
             ("Lightness", DESATURATE_LIGHTNESS),
            ("Luminosity", DESATURATE_LUMINOSITY),
            ("Average", DESATURATE_AVERAGE)
    extreme_unsharp_desaturation, menu="<Image>/Filters/Enhance")  # second item is menu location
main()
The entire code that gets the error:
def extreme_unsharp_desaturation_multi(image, drawable, radius, amount, desaturate_mode):
    num_images, image_ids = pdb.gimp_image_list() #function returns multiple values
    threshold = 0
register(
    "python-fu-extreme-unsharp-desaturation-multi",
    "Extreme unsharp and desaturate multi...",
    extreme_unsharp_desaturation_multi, menu="<Image>/Filters/Enhance")  # second item is menu location
main()
The contents of the other variables are populated by dialog or constants.
And the error:
File "C:\Program Files\GIMP 2\32\lib\gimp\2.0\python\gimpfu.py", line 736, in response
File "C:\Program Files\GIMP 2\32\lib\gimp\2.0\python\gimpfu.py", line 361, in run_script
File "C:\Users\david\.gimp-2.8\plug-ins\Extreme_Unsharp_Desaturation_multi.py", line 15, in extreme_unsharp_desaturation_multi
TypeError: wrong parameter type
PostPosted: Tue Mar 21, 2017 3:11 pm  (#5)
You use that statement, but then you ignore the results.
The result is a tuple (as you wrote): the number of images and the list of the images.
You have to scan the list of the images you've got (what you have called "images_ids"), not the tuple.
PostPosted: Tue Mar 21, 2017 4:49 pm  (#6)
Some remarks:
  • Don't use pdb.gimp_image_list() (which returns id) but gimp.image_list() (that returns gimp.Image objects)
  • Image and drawable args are not mandatory
  • You code loops applying unsharp-mask to the same drawable (the one from the image from which you call the script)
  • You need undo-group pairs on each image
  • "python-fu" is added autmatically
So:
def extreme_unsharp_desaturation_multi(radius, amount, desaturate_mode):
    threshold = 0
    for tempimage in gimp.image_list():
        pdb.gimp_image_undo_group_start(tempimage)
        pdb.plug_in_unsharp_mask(tempimage, tempimage.active_drawable, radius, amount, threshold)
        pdb.gimp_image_undo_group_end(tempimage)
register(
    "extreme-unsharp-desaturation-multi",
main()
PostPosted: Wed Mar 22, 2017 11:47 pm  (#7)
No I didn't ignore it, I tried scanning image_ids in addition to pdb.gimp_image_list(), got same error. As I should, they are equal. The subsequent poster has the answer, use gimp.image_list, not gimp_image_list, that actually returns objects not ids. I didn't read the original suggestion to do this closely enough earlier in the thread.
PostPosted: Wed Mar 22, 2017 11:48 pm  (#8)
Thanks ofnuts I'll give that shot.
