It is currently Sun Aug 23, 2026 7:48 am
 Post subject: YAWN (Yet Another Wannabee Neon)
PostPosted: Sat Apr 16, 2011 1:02 pm  (#1)
A quickie to transform any path into a neon sign, and more generally to draw a gradient across a path: Usage:
  • Define path. For text: use "stroke" fonts, and "path from text" in the text tool
    (see also my "unclose-path" plug-in)
  • Define current gradient, left color as darkest color, right color as lightest
  • In Paths dialog, right click on path, and select Decorate>Neon
  • Plugin will create layer with neon rendering of path
  • If a "Glow value is used, a second layer is generated with a blurred image
Help yourself at the usual place: http://sourceforge.net/projects/gimp-path-tools/
Enjoy.
 Post subject: Re: YAWN (Yet Another Wannabee Neon)
PostPosted: Sat Apr 16, 2011 2:32 pm  (#2)
Ofnuts, GLAD is customizing your next Wilber. Many thanks for this plug-in! :)
PostPosted: Sat Apr 16, 2011 2:44 pm  (#3)
Slinky meets Neon:
PostPosted: Sat Apr 16, 2011 3:00 pm  (#4)
That is awesome (and I didn't think of using Slinky, how clever!)
PostPosted: Sat Apr 16, 2011 3:02 pm  (#5)
slinky + neon looks very cool
PostPosted: Sat Apr 16, 2011 3:26 pm  (#6)
SpyroGimp + Path Created + Neon
Very Odd Looking, whatcha guys think?
I'm back I think
PostPosted: Sat Apr 16, 2011 3:34 pm  (#7)
My stuff looks like a strange physics experiment, yours like a strange biology experiment, there is a trend there...
PostPosted: Sat Apr 16, 2011 3:43 pm  (#8)
:rofl
I'm back I think
PostPosted: Sat Apr 16, 2011 4:06 pm  (#9)
I hope PC Doesn't mind that I used one of their patters
I'm back I think
PostPosted: Sat Apr 16, 2011 7:01 pm  (#10)
Wow add some chips and instant mother board Willy! :)
ofnuts what can i say - Should i just keep the rain gear on?
Nice filter.
I love to see anything to do with Paths added to Gimp.
Hrmmm perhaps a Neon Wilber?
PostPosted: Tue Nov 08, 2016 7:28 pm  (#11)
Ofnuts Neon Path is not working in 2-8-18, could you please check (probably a brush problem)
PostPosted: Wed Nov 09, 2016 2:59 am  (#12)
Fixed, see neon-path-0.2 at the usual place. Thanks for reporting.
PostPosted: Wed Nov 09, 2016 4:00 am  (#13)
What is the name of the font that ofnuts used in the first post image ?
I have trouble getting good looking results with my fonts.
PostPosted: Wed Nov 09, 2016 5:24 am  (#14)
That was an engraving font (a.k.a. 'stick font'). Unfortunately Gimp dropped all support for them since. So now you have to find a slim font that looks good, and make your paths over it.
PostPosted: Fri Mar 10, 2017 1:26 am  (#15)
Hi Ofnuts
This is my try on a botanical stuff.
PostPosted: Fri Mar 10, 2017 4:12 am  (#16)
If desperate, a couple of work-arounds if hand tracing does not appeal.
1. For linux users, Inkscape (0.9x version) has a trace centerline extension (plugin) that takes a png from Gimp and produces a path. Import the resulting svg back into Gimp. screenshot http://i.imgur.com/8s2eHyj.jpg
2. An very indirect route but CAD users will know the typical 'stick' fonts in use.
This for LibreCAD. Create the text. Export as a PDF. PDF into Inkscape. Export as a .svg file. Import the .svg into gimp. screenshot http://i.imgur.com/Rbh9ggg.jpg
looking at Rashid's drawing you could do that LibreCAD very easily as single lines, then there is a export as a 'engraving' svg that from memory Gimp will open. Unfortunately not true for text hence the route via Inkscape.
PostPosted: Sat Mar 11, 2017 6:22 am  (#17)
You can use type1 fonts (pfm+pfb). They won't display correctly in Gimp but running "text to path" creates single line paths of the font.
Or in Inkscape path/object to path.
I have lots of type1 fonts from old software, unfortunately they need to be installed into windir/fonts, because NexusFont or FontRunner won't load them.
edit: dropping them to Gimp fonts folder seems to work too, woohoo!
Tested Euro:
Inkscape 0.91 and later includes "Hershey Text" Extension but there's only few fonts.
 Post subject: less yawning
PostPosted: Mon Mar 13, 2017 6:36 am  (#18)
Alternative title
NION: Neon Isn't Only Neon
[sic]
that was all kinds of awesome. Suffering windows (for certain steam games) here I used choco (what passes for a package manager) to install inkscape.
jabber texting: liberate friends and family from the financial burden and backwardness of sms texting
PostPosted: Mon Mar 13, 2017 7:24 am  (#19)
What I actually wrote was
