It is currently Sun Aug 23, 2026 11:51 pm
 Post subject: Python Fu gimp_paintbrush
PostPosted: Thu Apr 20, 2017 8:41 am  (#1)
I'm trying to stamp an image with an overlay and when I use gimp_paintbrush it stamps with the current foreground color, but the brush is multicolored. The documentation says that it will do that. Is there a hack to get it to do what I want it to do?
Thanks!
 Post subject: Re: Python Fu gimp_paintbrush
PostPosted: Thu Apr 20, 2017 9:30 am  (#2)
Thanks!
Does the brush appear multicolored within the Brush Toolbox?
Such as the brush,
which can be seen in the screenshot below.
PostPosted: Thu Apr 20, 2017 9:38 am  (#3)
Yes, I figured out my error. My gradient length was set to 1 instead of 0.
This ended up working:
pdb.gimp_paintbrush(drawable, 0, 2, (image.width/2,image.height/2), PAINT_CONSTANT, 0)
PostPosted: Thu Apr 20, 2017 9:43 am  (#4)
:jumpclap
