It is currently Wed Aug 26, 2026 3:20 am
 Post subject: new filter "Shining"
PostPosted: Sun Apr 23, 2017 12:35 pm  (#1)
During the last days I had the opportunity to post some "plays" done with this sequence of steps, and I got positive feedbacks.
Thus I decided to release it as a filter to be used by everybody.
http://gimpscripts.com/2017/04/shining/
It creates:
- one work new image where two intermediate results and the final outcome are present as layers
- one "montage" (2*2) of the original and the 3 effects created.
It has no prerequisites (the "luma invert" effect instead of being realized using the existing script has been "translated" and embedded).
Enjoy.
 Post subject: Re: new filter "Shining"
PostPosted: Sun Jul 08, 2018 6:26 pm  (#2)
Dear Dinasset, I am not able to access gimpscripts.com to download (gimpscripts.com/2017/04/shining/).
Do you think you can post the filter as attachment. I am newbie in this site.
-Eureka
PostPosted: Sun Jul 08, 2018 7:00 pm  (#3)
What Gimp version are you using and what operating system?
PostPosted: Sun Jul 08, 2018 10:30 pm  (#4)
@Eureka
This is the filter as released in 2017 (for Gimp 2.8).
DIEGO_COLOURS_Shining.7z [3.08 KiB]
Downloaded 109 times
PostPosted: Mon Jul 09, 2018 6:58 pm  (#5)
My Gimp version is 2.8.22 Windows 10.
I will download the filter.
Thanks a ton.
- Eureka
