It is currently Mon Aug 10, 2026 2:56 am
 Post subject: new script-" Find Help"-(Gimp Help Forum,VideoTutorial+ browse CC)
PostPosted: Mon Apr 18, 2011 5:06 am  (#1)
Thank to Rod that find and modify and posted here a nice "links" script .
I removed some of the gimp forum links added links for my favorite Video Tutorial side , replaced the links for a stock side with that for CreativeCommons search
The script now add 3 submenu, 2 in Help ("Help Forum", and "Video Tutorial") and 1 in Image (Browse "CreativeCommons")
links are for GimpChat,GimpTalk, the Flickr Gimpusers Group, MeetTheGimp,Gimptrick (on youtube), and the CreativeCommons search
But is very simple modify or add new links
;based on a script from John Laubach <[email protected]>
;revised by Rod ;http://www.gimpchat.com/viewtopic.php?f=9&t=395&p=19368#p19368
;last edit by PhotoComix
(define (gimpchat)
(plug-in-web-browser "http://www.gimpchat.com/")
(define (gimptalk)
(plug-in-web-browser "http://www.gimptalk.com/")
(define (flickr-gimpusers-group)
(plug-in-web-browser "http://www.flickr.com/groups/gimpusers/discuss/")
(define (Meet-the-gimp)
(plug-in-web-browser "http://meetthegimp.org/getting-the-old-shows/")
(define (GimpTrick)
(plug-in-web-browser "http://www.youtube.com/user/GIMPtricks")
(define (CreativeCommons)
(plug-in-web-browser "http://search.creativecommons.org/")
(script-fu-register "gimpchat"
_"_GimpChat"
_"most active & friendly GIMP forum"
"PhotoComix <[email protected]>"
"2011"
(script-fu-menu-register "gimpchat"
"<Image>/Help/Help Forum/")
(script-fu-register "gimptalk"
_"_GimpTalk"
_"another friendly gimp forum"
"2011"
(script-fu-menu-register "gimptalk"
(script-fu-register "flickr-gimpusers-group"
_"_Gimpusers on Flickr"
_"Gimpusers group on Flickr"
"2011"
(script-fu-menu-register "flickr-gimpusers-group"
(script-fu-register "Meet-the-gimp"
_"_ MeetTheGimp"
_"Most large collection of excellent video-tutorial"
"2011"
(script-fu-menu-register "Meet-the-gimp"
"<Image>/Help/Video Tutorial/")
(script-fu-register "GimpTrick"
_"_GimpTrick"
_"Excellent video-tutorial"
"2011"
(script-fu-menu-register "GimpTrick"
(script-fu-register "CreativeCommons"
_"_Browse CreativeCommons "
_"search images licenced as Creative Commons"
"2011"
(script-fu-menu-register "CreativeCommons"
"<Image>/Image/")
 Post subject: Re: script - More helpful links-(help Forum, VideoTutorial, browse CC)
PostPosted: Mon Apr 18, 2011 5:18 am  (#2)
PS feel free to suggest changes, i will not like add more submenu but i may add more entries
(my idea was
select only the very best to keep it simple and avoid too much new menu entry)
 Post subject: Re: new script-" Find Help"-(Gimp Help Forum,VideoTutorial+ browse CC)
PostPosted: Mon Apr 18, 2011 3:00 pm  (#3)
Maybe add the Tutorial Indexs for GIMP Talk and GIMP Chat in there?
I'm back I think
PostPosted: Wed Apr 20, 2011 2:54 am  (#4)
As comment in the script i added a template , to help to modify the script as example to add a link for non english gimp forums, or anyway other sides.
Not sure if is clear , any suggestion to make that sort to "how to" part more clear is welcome
all the changes are in the comment so nothing change in what this script does
Here i highlight the comment
;revisited by Rod ;http://www.gimpchat.com/viewtopic.php?f=9&t=395&p=19368#p19368
;Last edit by PhotoComix
; to modify this script to your needs
;you may add new link, as example for a gimp forum in your language
;using this template: to add a link for side X
;this is to define X (scroll for the matching register part )
;(define (NAME OF THE SITE)
; (plug-in-web-browser "SITE URL HERE")
(define (gimpchat)
(define (gimptalk)
(define (GimpTrick)
;this is to register X ,after the empty line
"NAME OF THE SITE" FOR X should be the same name used in "define X")
;(script-fu-register "NAME OF THE SITE"
; _"_Name for menu entry"
; _"tooltip text here"
; "PhotoComix <[email protected]>"
; "2011"
;(script-fu-menu-register "gimpchat"
; "<Image>/Help/Help Forum/")
;you may edit "<Image>/Help/Help Forum/" to use a different menu
_"_GimpChat"
"2011"
_"_GimpTalk"
"2011"
"2011"
_"_ MeetTheGimp"
"2011"
_"_GimpTrick"
"2011"
"2011"
"<Image>/Image/")
aaargh!! a smile popped inside the code :gaah !
PostPosted: Wed Apr 20, 2011 2:11 pm  (#5)
I fixed it PC. :)
cron
