It is currently Sat Aug 22, 2026 6:54 am
 Post subject: Plug-ins Gimp-2.8_win_32bit Nufraw-0.40 & Ufraw 0.22
PostPosted: Sat May 20, 2017 10:46 am  (#1)
Downloads (only 32 bit):
https://www.dropbox.com/s/vc9fhtpuyjhm8ns/Plug-ins%20Gimp-2.8_win_32bit%20Nufraw-0.40%20%26%20Ufraw%200.22.zip?dl=0
Nufraw source download:
https://sourceforge.net/projects/nufraw/files/
UFRaw source download:
https://sourceforge.net/projects/ufraw/files/ufraw/
The zip package also includes the latest version Lensfun:
http://lensfun.sourceforge.net/
Each build depends on the environment (msys32) - so use may cause incompatibility of the *.dll.
You have to accept the principle of not mixing (replacing) files from different sources.
The translation action is very specific to this plugin:
- the translation files should be placed in the lib\locale directory,
- place the folder "nufraw" in the c: \Program Files\GIMP 2\lib\gimp\2.0 folder and add it in the Preferences/Folders/Plug-Ins directory.
If you place the directory "nufraw" in another location, eg in the home directory .gimp-2.8 (also after adding this directory in Preferences)
will only work in English version.
It is also worth trying GimpLensfun (gimp-lensfun.exe).
https://seebk.github.io/GIMP-Lensfun/
In menu:
<Image>/Filters/Enhance/GimpLensfun...
