| Script Coder |
Ok, so I've been trying to make a plugin that uses a GTK interface, using this http://www.gimphelp.org/scripts/script_ ... sharpen.py as a template. I'm trying to create a dummy/test plugin that does nothing except creates a new layer. However, I just can't get it to work! It shows up in the filters menu but does nothing, doesn't display the dialog... I'm frustrated and I can't find what is wrong with it. Can anyone help me find out what I'm doing wrong here? Here's my source code: #!/usr/bin/env python # -*- coding: utf-8 -*- #
import gimp, gimpplugin, math from gimpenums import * pdb = gimp.pdb import gtk, gimpui, gimpcolor from gimpshelf import shelf
class reuse_init(object): previewLayer = None
def get_layer_pos(self, layer): i = 0 while i < len(self.img.layers): if layer == self.img.layers[i]: return i else: i += 1 return -1
def layer_exists(self, layer): return layer != None and layer in self.img.layers
def removePreviews(self): if self.layer_exists(self.previewLayer): self.img.remove_layer(self.previewLayer) self.previewLayer = None gimp.displays_flush()
def make_label(self, text): label = gtk.Label(text) label.set_use_underline(True) label.set_alignment(1.0, 0.5) label.show() return label
def make_slider_and_spinner(self, init, min, max, step, page, digits): controls = {'adj':gtk.Adjustment(init, min, max, step, page), 'slider':gtk.HScale(), 'spinner':gtk.SpinButton()} controls['slider'].set_adjustment(controls['adj']) controls['slider'].set_draw_value(False) controls['spinner'].set_adjustment(controls['adj']) controls['spinner'].set_digits(digits) controls['slider'].show() controls['spinner'].show() return controls
def show_error_msg(self, msg): origMsgHandler = pdb.gimp_message_get_handler() pdb.gimp_message_set_handler(ERROR_CONSOLE) pdb.gimp_message(msg) pdb.gimp_message_set_handler(origMsgHandler)
def stringToColor(self, string): colorlist = string[5:-1].split(", ") return gimpcolor.RGB(float(colorlist[0]), float(colorlist[1]), float(colorlist[2]), float(colorlist[3]))
class testplugin(reuse_init): def __init__(self, runmode, img, drawable, param1, param2): self.img = img self.drawable = drawable self.shelfkey = 'test-plugin' self.showDialog()
def showDialog(self): self.dialog = gimpui.Dialog("Bheeeeps BAA!", "thedialog")
self.table = gtk.Table(20, 4, True) self.table.set_homogeneous(False) self.table.set_row_spacings(8) self.table.set_col_spacings(8) self.table.show()
#param1 self.label1 = self.make_label("Baa:") self.table.attach(self.label1, 0, 1, 1, 2)
self.spinner1 = self.make_slider_and_spinner(10.0, 1.0, 20.0, 1.0, 10.0, 1) self.spinner1['adj'].set_value(10.0) self.table.attach(self.spinner1['slider'], 1, 2, 1, 2) self.table.attach(self.spinner1['spinner'], 2, 3, 1, 2)
#param2 self.label2 = self.make_label("Boo:") self.table.attach(self.label2, 0, 1, 2, 3)
self.spinner2 = self.make_slider_and_spinner(10.0, 0.0, 20.0, 0.1, 1.0, 1) self.spinner2['adj'].set_value(10.0) self.table.attach(self.spinner2['slider'],1,2,3,4) self.table.attach(self.spinner2['spinner'],2,3,3,4)
# self.flatten_check = gtk.CheckButton("Flatten layer when complete") # self.flatten_check.show() # self.table.attach(self.flatten_check, 3, 4, 1, 2)
self.dialog.vbox.hbox1 = gtk.HBox(False, 7) self.dialog.vbox.hbox1.show() self.dialog.vbox.pack_start(self.dialog.vbox.hbox1, True, True, 7) self.dialog.vbox.hbox1.pack_start(self.table, True, True, 7)
reset_button = gtk.Button("_Reset") reset_button.connect("clicked", self.resetbutton) reset_button.show()
self.preview_button = gtk.Button("Preview") self.preview_button.connect("clicked", self.preview) self.preview_button.set_size_request(100, -1) self.preview_button.show()
if gtk.alternative_dialog_button_order(): ok_button = self.dialog.add_button(gtk.STOCK_OK, gtk.RESPONSE_OK) cancel_button = self.dialog.add_button(gtk.STOCK_CANCEL, gtk.RESPONSE_CANCEL) self.dialog.action_area.add(reset_button) self.dialog.action_area.add(self.preview_button) else: self.dialog.action_area.add(self.preview_button) self.dialog.action_area.add(reset_button) cancel_button = self.dialog.add_button(gtk.STOCK_CANCEL, gtk.RESPONSE_CANCEL) ok_button = self.dialog.add_button(gtk.STOCK_OK, gtk.RESPONSE_OK) ok_button.connect("clicked", self.okbutton)
self.dialog.show() self.dialog.run() self.removePreviews()
def okbutton(self, widget): # remove old preview layer if it exists if self.layer_exists(self.previewLayer): self.img.remove_layer(self.previewLayer) self.previewLayer = None
# get values of the settings param1 = self.spinner1['adj'].get_value() param2 = self.spinner2['adj'].get_value() # if self.flatten_check.get_active(): # flatten = 1 # else: # flatten = 0
# then build new layer with current settings to actually impliment... # the True value at the end means it is a Final layer sent to "makeLayer" # hence it will flatten image if this is chosen (previews will not) fxlayer = self.makeLayer(self.img, self.drawable, param1, param2)
def resetbutton(self, widget): self.spinner1['adj'].set_value(10.0)
def preview(self, widget): ptxt = self.preview_button.get_label()
if self.layer_exists(self.previewLayer): self.img.remove_layer(self.previewLayer) gimp.displays_flush()
else: param1 = self.spinner1['adj'].get_value() param2 = self.spinner2['adj'].get_value() self.previewLayer = self.makeLayer(self.img, self.drawable, param1, param2)
if ptxt == "Preview": ptxt = "Undo Preview" else: ptxt = "Preview" self.preview_button.set_label(ptxt)
def makeLayer(self, img, drawable, param1, param2): pdb.gimp_image_undo_group_start(img)
tmpLayer1 = pdb.gimp_layer_copy(drawable, True)
pdb.gimp_image_add_layer(img, tmpLayer1, -1)
gimp.displays_flush() pdb.gimp_image_undo_group_end(img) return tmpLayer1
class pyTestplugin(gimpplugin.plugin): def start(self): gimp.main(self.init, self.quit, self.query, self._run)
def init(self): pass
def quit(self): pass
def query(self): authorname = "dd" copyrightname = "dd" menu_location = "<Image>/Filters/Testplugin..." date = "2011" plug_description = "A test plugin" plug_help = "A test plugin" plug_params = [ (PDB_INT32, "run_mode", "Run mode"), (PDB_IMAGE, "image", "Input image"), (PDB_DRAWABLE, "drawable", "Input drawable"), ####### 3 params above needed by all scripts using gimpplugin.plugin ###################### (PDB_FLOAT, "param1", "First parameter"), (PDB_FLOAT, "param2", "Second parameter")]
gimp.install_procedure("py_testplugin", plug_description, plug_help, authorname, copyrightname, date, menu_location, "RGB*, GRAY*", PLUGIN, plug_params, [])
def py_testplugin(self, runmode, img, drawable, param1, param2): testplugin(runmode, img, drawable, param1, param2)
if __name__ == '__main__': pyTestplugin().start()
