It is currently Mon Aug 24, 2026 12:17 am
 Post subject: Group offset script
PostPosted: Tue Jun 13, 2017 6:58 am  (#1)
Hi, does anyone know if there is a newer version or something similar to this plug-in available, http://registry.gimp.org/node/26996
this version doesn't work with 2.8.22
thanks
 Post subject: Re: Group offset script
PostPosted: Tue Jun 13, 2017 8:06 am  (#2)
Could you be more specific than "doesn't work with 2.8.22" ... what doesn't work? Do you get an error message?
Kevin
PostPosted: Tue Jun 13, 2017 8:41 am  (#3)
Actually a new Gimp bug it seems: https://bugzilla.gnome.org/show_bug.cgi?id=783742
See below for a work around (script is slightly different: Menu is in Layer/Transform)
group_offset.zip [821 Bytes]
Downloaded 182 times
PostPosted: Tue Jun 13, 2017 10:43 am  (#4)
Kevin
Apologies for the vagueness Kevin, I started writing then realised I had to rush out the door, so finished the post abruptly like that.. :oops: TBH can't remember the error message, just knew it didn't work lol
Brilliant, thanks ofnuts, that works a treat, now I can offset groups to my hearts content! :coolthup :yes :gimp :tyspin
PostPosted: Sun Jun 18, 2017 8:29 am  (#5)
The real question is whether anyone has successfully used this with 2.8.x... I'm tracking the bug and it seems to have been there since 2.8.0.
