It is currently Sun Aug 23, 2026 8:23 pm
 Post subject: I made a Gimp-Gap package for Ubuntu 16.04
PostPosted: Sat Jul 01, 2017 6:06 am  (#1)
GnuTux's 2012 method of compiling gimp-gap for Ubuntu no longer works. There has been some development of the gimp-gap plugin and the ffmpeg video encoder bugs have been fixed.
Thanks to telperion for his encouragement.
Built with the github master @June 30 2017. Tested on Gimp 2.8.22.
UPDATE - There are 2 versions available.
https://drive.google.com/file/d/0ByhCySqrqAmqQjZTblM3ZGMwU0E/view
This pack is for 64bit Ubuntu 16.04-based distros and has one dependency, libfaac0.
https://drive.google.com/file/d/0ByhCySqrqAmqdUNpbjRmYTlHZWs/view
This pack is for 64bit Ubuntu 14.04-based distros and has one dependency, libfaac0.
Gimp-gap has become quite hard to compile with a large number of dependencies.
I called this gimp-gap 2.8-1 which is a bit mischievous because the github branch is still on 2.7 although they have included the 2.8 branch. I'm trying to encourage them to finish 2.8 and accept more communication with the user base.
For example I can't find any google group or technical forum to discuss gap patches.
https://github.com/GNOME/gimp-gap
https://groups.google.com/forum/#!forum/gimp-gap
 Post subject: Re: I made a Gimp-Gap package for Ubuntu 16.04
PostPosted: Sun Jul 02, 2017 8:56 am  (#2)
I wonder if this could be re compiled for windows then.
PostPosted: Sun Jul 02, 2017 9:00 am  (#3)
This makes me think that most PDB functions for GIMP-2.8.22 will not work in the GAP plug-ins.
- gimp 2.8.0 or higher.
This release was tested with gimp-2.8.10
Note: GIMP-GAP provides some features that are able to call many of the
GIMP standard filters. (plug-in programs that are shiped with
gimp-2.8.10) Those features depend on the tested PDB interface
versions and may fail if newer version are used.
PostPosted: Sun Jul 02, 2017 11:08 am  (#4)
@Rod
in gimp 2.8.xx series, there are not pdb interface changes, only bug fix for the "xx" release.
pdb interface change from gimp 2.6 to gimp 2.8.
gimp-gap 2.6.0 is broken in some functionallity because it's for gimp 2.6.x.
Example: with gimp 2.8.x, Animated Map Object fails with gimp-gap 2.6.0,
but work perfectly whit gimp-gap git.
My gimp is 2.8.23, gap is 2.7.0 (git master, configure.in version is 2.7.0)
For gimp 2.8.x you need gimp-gap 2.8 branch (or master, for now it's almost the same).
See:
https://bugzilla.gnome.org/show_bug.cgi?id=749290
PostPosted: Sun Jul 02, 2017 5:37 pm  (#5)
I installed gimp-gap, though I can't make heads or tails out of it yet. If I make something interesting, I'll post an example here.
PostPosted: Sun Jul 02, 2017 7:00 pm  (#6)
Hi racer-x.
Filters > Filter all Layers is very useful although not all of the many filters work on all layers.
Here I applied an 'alienmap' filter to a double animation of bacteria on an animated background of human blood cells.
I then use Video> Master Videoencoder to make an AVI.
Previously this would cause 'skips' in my animations because Videoencoder was dropping frames. This has now been fixed in gimp-gap.
GAP can turn a video into frames and can animate tweens although I haven't done that yet.
PostPosted: Mon Jul 03, 2017 6:28 am  (#7)
telperion wrote:
@Rod
See:
GIMP-2.8.23 was released?
PostPosted: Mon Jul 03, 2017 11:43 am  (#8)
Kubuntu 16.04 / Gimp 2.8.22 / Gimp 2.9.5
Just a quick try-out, I unpacked the deb so I could add the plug-ins/scripts locally.
From Rod's references I thought it might work with Gimp 2.9.5 but lots of error messages even with compatibility mode on.
Gimp 2.8.22 is better, extracts frames from a .mp4 ok and I vaguely remember how morph works, I need a refresher course ;)
PostPosted: Mon Jul 03, 2017 1:10 pm  (#9)
For gimp 2.9.5 gap must be builded with libgimp of gimp 2.9.5, because pdb change again from 2.8.
It's works partially, some issue like gap 2.6.0 whit gimp 2.8.xx.
e.g Animated Map Object:
initial key ok, then start calculate intermediate frames, without set final key = all frames are the same.
PostPosted: Mon Jul 03, 2017 6:25 pm  (#10)
I setup a google group for gimp-gap compiling issues here:
I'm guessing most Gimp Chat users are not interested in compiling their own plugins.
Also the gimp-gap compiling issues will be around for a long time by the look of it... :gimp
